跳转到主内容
加入维修社区 - 创建账户
Upper Ice Maker Assembly Replacement
你所需要的
  1. Upper Ice Maker Assembly Replacement, Unplug your refrigerator: 步骤 1 中的图像 1,1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser Fan Motor
    • Compressor Motor and Thermal Overload Device
    • Water Supply Valve Assembly
  2. Upper Ice Maker Assembly Replacement, Open the doors: 步骤 2 中的图像 1,3 Upper Ice Maker Assembly Replacement, Open the doors: 步骤 2 中的图像 2,3 Upper Ice Maker Assembly Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Open both refrigerator doors fully.
  3. Upper Ice Maker Assembly Replacement, Open the ice maker door: 步骤 3 中的图像 1,3 Upper Ice Maker Assembly Replacement, Open the ice maker door: 步骤 3 中的图像 2,3 Upper Ice Maker Assembly Replacement, Open the ice maker door: 步骤 3 中的图像 3,3
    • Pull down the latch handle to release the ice maker door.
    • Swing open the ice maker door.
  4. Upper Ice Maker Assembly Replacement, Remove the ice bucket: 步骤 4 中的图像 1,3 Upper Ice Maker Assembly Replacement, Remove the ice bucket: 步骤 4 中的图像 2,3 Upper Ice Maker Assembly Replacement, Remove the ice bucket: 步骤 4 中的图像 3,3
    • Using two hands, lift up the ice bucket slightly to release it.
    • Pull the bottom edge of the ice bucket toward you slightly and remove it.
  5. Upper Ice Maker Assembly Replacement, Reassembly notes: 步骤 5 中的图像 1,3 Upper Ice Maker Assembly Replacement, Reassembly notes: 步骤 5 中的图像 2,3 Upper Ice Maker Assembly Replacement, Reassembly notes: 步骤 5 中的图像 3,3
    • The drive hub notches and drive blade wings must line up before installing the ice bucket.
    • Rotate the ice bucket hub, located on the rear of the ice bucket, with your hand so that the notches will align with the auger motor drive blades.
  6. Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: 步骤 6 中的图像 1,2 Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: 步骤 6 中的图像 2,2
    • Use a #2 Philips driver to remove the three 15 mm‑long screws that secure the ice maker assembly to the refrigerator door.
  7. Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: 步骤 7 中的图像 1,3 Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: 步骤 7 中的图像 2,3 Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: 步骤 7 中的图像 3,3
    • Use a spudger to lift the bottom edge of the ice maker assembly. This action will release the assembly from the refrigerator door.
    • Pull the bottom edge of the ice maker assembly toward you to free it from the door.
  8. Upper Ice Maker Assembly Replacement: 步骤 8 中的图像 1,3 Upper Ice Maker Assembly Replacement: 步骤 8 中的图像 2,3 Upper Ice Maker Assembly Replacement: 步骤 8 中的图像 3,3
    • Lower the ice maker assembly until you can access the connector located at the top of the assembly.
    • Squeeze the connector at the top of the ice maker assembly to release it.
    • Pull the connector straight down to disconnect it.
  9. Upper Ice Maker Assembly Replacement, Remove the ice maker assembly: 步骤 9 中的图像 1,1
    • Remove the ice maker assembly.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
于06/30/22注册
38,785 声望
创作了261篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 15
总计 183
