跳转到主内容
Turtle Beach Ear Force XO Four Speaker Cone Replacement
你所需要的
  1. Turtle Beach Ear Force XO Four Speaker Cone Replacement, Ear Cushion: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Jimmy
    $7.95
    购买
    • Insert a flat metal object (such as iFixit's Jimmy tool) between the green and black plastic portions of the headset.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  2. Turtle Beach Ear Force XO Four Speaker Cone Replacement: 步骤 2 中的图像 1,2 Turtle Beach Ear Force XO Four Speaker Cone Replacement: 步骤 2 中的图像 2,2
    • Carefully pry the plastic pieces apart, working your way around the ear cushion.
    • Be sure not to break the tabs on the back side of the ear pad!
  3. Turtle Beach Ear Force XO Four Speaker Cone Replacement: 步骤 3 中的图像 1,3 Turtle Beach Ear Force XO Four Speaker Cone Replacement: 步骤 3 中的图像 2,3 Turtle Beach Ear Force XO Four Speaker Cone Replacement: 步骤 3 中的图像 3,3
    • Pull the loosened ear pad apart from the rest of the speaker.
    • Pushing the pad and the speaker back together is the only step required for ear pad reassembly.
  4. Turtle Beach Ear Force XO Four Speaker Cone Replacement, Speaker Cone: 步骤 4 中的图像 1,2 Turtle Beach Ear Force XO Four Speaker Cone Replacement, Speaker Cone: 步骤 4 中的图像 2,2
    • Remove four 7.3mm PH0 screws.
    • As these screws are very small, it may be best to keep them in a plastic bag or other container.
  5. Turtle Beach Ear Force XO Four Speaker Cone Replacement: 步骤 5 中的图像 1,2 Turtle Beach Ear Force XO Four Speaker Cone Replacement: 步骤 5 中的图像 2,2
    • Lift speaker cone off of the back casing.
    • Be gentle; the small wires connecting the speaker cone to the rest of the device may break if you pull too hard.
    • Follow iFixit's soldering guide to remove the wires connected to the speaker.
结论
9等其他人完成本指南。
Evalyn Johnson
于09/22/15注册
228 声望
创作了2篇指南
团队
Baylor, Team 10-14, Williams Fall 2015 Baylor, Team 10-14, Williams Fall 2015 的会员
BU-WILLIAMS-F15S10G14
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 9,384
