跳转到主内容
Turtle Beach Ear Force X12 Microphone Replacement
你所需要的
  1. Turtle Beach Ear Force X12 Microphone Replacement, Ear Pads: 步骤 1 中的图像 1,1
    • Start by removing the left ear pad.
    • Gently pull on the pad from the side by the leathery material until it comes loose from slot.
    • Be careful not to rip the fabric.
  2. Turtle Beach Ear Force X12 Microphone Replacement: 步骤 2 中的图像 1,1
    • Grip ear cushion and carefully pull up and separate from the plastic headphone.
  3. Turtle Beach Ear Force X12 Microphone Replacement: 步骤 3 中的图像 1,2 Turtle Beach Ear Force X12 Microphone Replacement: 步骤 3 中的图像 2,2
    • Your headset should look like the first picture, with the left cushion removed.
    • Repeat these steps for right cushion.
    • You may now continue with more complex inner headset repair, or replace the ear pads by sliding on new ones in the slot.
  4. Turtle Beach Ear Force X12 Microphone Replacement, Microphone: 步骤 4 中的图像 1,2 Turtle Beach Ear Force X12 Microphone Replacement, Microphone: 步骤 4 中的图像 2,2
    • Remove the three 1.1 mm screws around the speaker using a T3 screwdriver.
    • Open the top panel carefully.
    • Potential for device damage: The wires are very delicate and can be broken easily.
  5. Turtle Beach Ear Force X12 Microphone Replacement: 步骤 5 中的图像 1,2 Turtle Beach Ear Force X12 Microphone Replacement: 步骤 5 中的图像 2,2
    • Remove the 5 mm screw using a Phillips #00 screwdriver.
    • Carefully pull the wire to the side to allow access to the screw if necessary.
  6. Turtle Beach Ear Force X12 Microphone Replacement: 步骤 6 中的图像 1,2 Turtle Beach Ear Force X12 Microphone Replacement: 步骤 6 中的图像 2,2
    • Cut the microphone wire with wire cutters.
    • Desolder the microphone wires.
    • Practice caution while soldering. Ensure proper safety and soldering procedure is followed to avoid component damage and injury.
    • For more information on soldering, check out this guide.
  7. Turtle Beach Ear Force X12 Microphone Replacement: 步骤 7 中的图像 1,2 Turtle Beach Ear Force X12 Microphone Replacement: 步骤 7 中的图像 2,2
    • Insert the new microphone and solder the wires into the correct positions.
    • Position the speaker on the headset so the screw holes are aligned.
结论
Maria Fontiveros
于10/02/17注册
101 声望
撰写一个指南
团队
USF Tampa, Team S1-G3, Thompson Fall 2017 USF Tampa, Team S1-G3, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S1G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,926
