跳转到主内容
Turtle Beach Ear Force P11 Speakers Replacement
你所需要的
  1. Turtle Beach Ear Force P11 Speakers Replacement, Ear Cushion: 步骤 1 中的图像 1,1
    • Pinch the inner edge of the ear cushion from the bottom.
  2. Turtle Beach Ear Force P11 Speakers Replacement: 步骤 2 中的图像 1,1
    • Now slowly pull down the ear cushion as it completely separates from the speaker.
    • Carry out the pulling down action as slowly as possible or you might risk tearing the ear cushion otherwise
  3. Turtle Beach Ear Force P11 Speakers Replacement, Speakers: 步骤 3 中的图像 1,1
    • Remove the 4 screws on the red speaker cover.
    • It is recommended to use a #000 Philips Screw Driver
  4. Turtle Beach Ear Force P11 Speakers Replacement: 步骤 4 中的图像 1,2 Turtle Beach Ear Force P11 Speakers Replacement: 步骤 4 中的图像 2,2
    • Inspect the wires for damage as illustrated
  5. Turtle Beach Ear Force P11 Speakers Replacement: 步骤 5 中的图像 1,1
    • De-solder the speaker wires and remove the speaker.
    • Use low heat for de - soldering
  6. Turtle Beach Ear Force P11 Speakers Replacement: 步骤 6 中的图像 1,1
    • Solder the new speaker wires in the same position as the old one.
    • It is advisable to use a lead free solder
    • Use a small amount of solder to not mix up the connections and prevent short circuiting.
    • In case you use a large amount of solder, use a solder wick to absorb the excess solder.
    • You can find more information on "How To Solder" here:如何焊接和拆焊
结论
4等其他人完成本指南。
Bhavesh Gandhi
于09/26/15注册
585 声望
创作了3篇指南
团队
IUPUI, Team 1-2, Wilson Fall 2015 IUPUI, Team 1-2, Wilson Fall 2015 的会员
IUPUI-WILSON-F15S1G2
2 名成员
创作了6篇指南
6条评论
can you fix mine contact me a jtrent238@outlook.com
jtrent238 - 回复
I am sorry jtrent238 , but i can further guide you on how you could solve the problem
Bhavesh Gandhi - 回复
If you look at step four you will see the black wire has a knot and a silver metal part. Well My wire has broken right there any advice? Please help!
Dev - 回复
Do you know where I can get the speakers from?
James Patrick - 回复
my problem exist in this area https://imgur.com/grLwOkt cant figure out how to detach the entire bud to get access to the internal wires
John - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 3,722
