跳转到主内容
Turtle Beach Ear Force P11 Microphone Replacement
你所需要的
  1. Turtle Beach Ear Force P11 Microphone Replacement, Microphone: 步骤 1 中的图像 1,1
    • Remove the microphone cover by unscrewing the screw on the front side of the microphone.
    • It is recommended to use #000 Philips head screwdriver.
  2. Turtle Beach Ear Force P11 Microphone Replacement: 步骤 2 中的图像 1,1
    • Use a nylon or metal spudger set to lift out the microphone.
    • Be careful lest you might break the fragile wires.
    • Always try using a plastic tool before resorting to a metal tool as shown in the picture.
  3. Turtle Beach Ear Force P11 Microphone Replacement: 步骤 3 中的图像 1,1
    • De-solder the microphone wires and remove the microphone.
    • Use low heat for de - soldering
    • Do not cut the white and black wires soldered to the microphone as you might reduce the length of wire required to reassemble.
  4. Turtle Beach Ear Force P11 Microphone Replacement: 步骤 4 中的图像 1,1
    • Solder the new microphone wires in the same position as the old one.
    • It is advisable to use a lead free solder
    • Use a small amount of solder to not mix up the connections and prevent short circuiting.
    • You can find more information on How to Solder here: 如何焊接和拆焊
    • To complete reassembly replace the cover taken off in step 1.
结论
另外一个人完成了本指南。
Bhavesh Gandhi
于09/26/15注册
585 声望
创作了3篇指南
团队
IUPUI, Team 1-2, Wilson Fall 2015 IUPUI, Team 1-2, Wilson Fall 2015 的会员
IUPUI-WILSON-F15S1G2
2 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,029
