跳转到主内容
加入维修社区 - 创建账户
Trio Stealth-G4X Camera Replacement
浏览量: 752
浏览统计数据:
过去24小时
2
过去 7 天:
18
过去 30 天:
75
总计
752
评论: 0
暂时还没有人对本指南发表评论。你想做第一个评论的人吗?
Go to guide comments
已完成: 0
暂时还没有人将本指南标记为“已完成”。你会是第一个完成的人吗?
收藏: 0
暂时还没有人收藏(和订阅)本指南。你会是第一个收藏(和订阅)的人吗?
所需时间: 10 - 20 分钟
难度: 简单
不正确的工具
通过在图片或文字中使用正确的工具来帮助完善该指南
This guide will demonstrate how to replace the camera in a Trio Stealth-G4X tablet. You may be experiencing malfunctions with your camera such as blurry pictures, a broken lens, the camera not taking pictures, etc. These problems may be caused by a damaged camera that needs to be replaced. However, make sure that the camera is damaged and you are not experiencing a software issue before attempting this replacement. You can check the troubleshooting page to see if your problem requires camera replacement or if it can be fixed otherwise.
你所需要的
工具
    1. Trio Stealth-G4X Camera Replacement, Camera: 步骤 1 中的图像 1,1
      • Starting near the middle edge of the Trio Stealth-G4X tablet, gently work an opening pick or spudger in between the seams of one side of the tablet.
      询问修复机器人
      添加评论
    2. Trio Stealth-G4X Camera Replacement: 步骤 2 中的图像 1,1
      • Work your way around all four corners of the tablet, unlocking all of the retaining tabs that hold the tablet together. This will allow you to separate the two halves of the tablet and access the motherboard.
      • Be sure not to over penetrate while separating the two halves as you may damage the tablet's internal hardware.
      询问修复机器人
      添加评论
    3. Trio Stealth-G4X Camera Replacement: 步骤 3 中的图像 1,1
      • Once the two halves are separated, set aside the back cover of the tablet as you will not need it until reassembly. Now locate the camera on the motherboard of the tablet.
      询问修复机器人
      添加评论
    4. Trio Stealth-G4X Camera Replacement: 步骤 4 中的图像 1,1
      • Peel back the yellow protective film on the motherboard to access the camera's ribbon cable.
      询问修复机器人
      添加评论
    5. Trio Stealth-G4X Camera Replacement: 步骤 5 中的图像 1,1
      • Take the Phillips head screwdriver and unscrew the 3mm screw right above the camera assembly. Place the screw aside so you do not lose it.
      询问修复机器人
      添加评论
    6. Trio Stealth-G4X Camera Replacement: 步骤 6 中的图像 1,1
      • Use a spudger to pry the black tab on this connection point upwards. This will unlock the ribbon cable that connects the camera to the motherboard.
      • Once unlocked, very carefully pull the cable out of the socket to disconnect it.
      • Be very delicate with the ribbon cable because it can tear easily.
      询问修复机器人
      添加评论
    7. Trio Stealth-G4X Camera Replacement: 步骤 7 中的图像 1,1
      • Now you can remove the camera assembly. Use a spudger to gently loosen the camera out of place.
      询问修复机器人
      添加评论
    8. Trio Stealth-G4X Camera Replacement: 步骤 8 中的图像 1,1
      • Grab the camera assembly with your fingers and gently lift it out of the tablet.
      询问修复机器人
      添加评论
    9. Trio Stealth-G4X Camera Replacement: 步骤 9 中的图像 1,1
      • You have now removed the camera assembly and can set it aside. Insert replacement camera by following the steps in reverse. Then reassemble the tablet the same way.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
作者
与
Emily Dorsey
于08/26/15注册
434 声望
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 75
总计 752
