跳转到主内容
Trio Stealth-10 Speaker Replacement
你所需要的
  1. Trio Stealth-10 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Speaker Replacement, Speaker: 步骤 2 中的图像 1,1
    • This next step will require you to solder a couple of wires off the motherboard. We recommend you get someone to help you if you are unfamiliar with soldering or use Ifixit's Soldering guide to help you.
    • Next you must solder off the wires that connect the speaker to the motherboard.
  3. Trio Stealth-10 Speaker Replacement: 步骤 3 中的图像 1,1
    • Next you will need to remove the two screws attached to the speaker. If you have a 54 bit Driver Kit use the Philips Head 0 (or PH 0) head to remove the two 4mm screws.
结论
另外一个人完成了本指南。
Daniel Coleman
于10/29/15注册
643 声望
创作了5篇指南
团队
UMass Dartmouth, Team 1-4, Miles Fall 2015 UMass Dartmouth, Team 1-4, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G4
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 363
