简介
If the screen/digitizer on your Trio Stealth-10 is no longer functioning, replacement isn't difficult and this guide will give you the step by step procedure to do so.
你所需要的
To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
在这个步骤中使用的工具:Tweezers$4.99
Disconnect the screen/digitizer connection. Use tweezers and pull each grey end of the connection until there is a small gap between the grey and white on the connector to the motherboard. The connection should be easily removable.
Pull the cable away and clear from under the battery to avoid damage to the connection.
Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
Use your spudger to disconnect the screen/digitizer connection from the motherboard.
3等其他人完成本指南。
