跳转到主内容
加入维修社区 - 创建账户
Trio Stealth-10 Battery Replacement
你所需要的
  1. Trio Stealth-10 Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Battery Replacement, Battery: 步骤 2 中的图像 1,1
    • This step will require soldering. If you are unfamiliar with soldering then we recommend that you get help from another person or use the soldering guide made by Ifixit to help.
    • Solder the connections off for the battery.
  3. Trio Stealth-10 Battery Replacement: 步骤 3 中的图像 1,2 Trio Stealth-10 Battery Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Disconnect the screen/digitizer connection. Use tweezers and pull each grey end of the connection until there is a small gap between the grey and white on the connector to the motherboard. The connection should be easily removable.
    • Pull the cable away and clear from under the battery to avoid damage to the connection.
  4. Trio Stealth-10 Battery Replacement: 步骤 4 中的图像 1,1
    • Pry battery up from adhesive. Use a type of adhesive remover. Nail polish remover works well.
结论
6等其他人完成本指南。
Daniel Coleman
于10/29/15注册
643 声望
创作了5篇指南
团队
UMass Dartmouth, Team 1-4, Miles Fall 2015 UMass Dartmouth, Team 1-4, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G4
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 2,429
