跳转到主内容
加入维修社区 - 创建账户
Trio Stealth Pro 9.7" Motherboard Replacement
你所需要的
  1. Trio Stealth Pro 9.7" Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove 2 black 4 cm Phillips screws on either side of the bottom of the device.
  2. Trio Stealth Pro 9.7" Motherboard Replacement: 步骤 2 中的图像 1,2 Trio Stealth Pro 9.7" Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tools and the spudger around the outside of silver metal back plate on the device to pry off the back plate.
  3. Trio Stealth Pro 9.7" Motherboard Replacement: 步骤 3 中的图像 1,3 Trio Stealth Pro 9.7" Motherboard Replacement: 步骤 3 中的图像 2,3 Trio Stealth Pro 9.7" Motherboard Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Unclip camera flex cable
    • Use plastic opening tool to lift open black clip where the flex cables are attached to the motherboard.
    • Then gently pull out the flex cable with tweezers.
  4. Trio Stealth Pro 9.7" Motherboard Replacement: 步骤 4 中的图像 1,2 Trio Stealth Pro 9.7" Motherboard Replacement: 步骤 4 中的图像 2,2
    • Unclip large orange flex cable.
  5. Trio Stealth Pro 9.7" Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove flex cable clip in top left area of motherboard.
    • Use plastic opening tool to lift open black clip where the flex cables are attached to the motherboard. gently pull out the flex cable with tweezers.
  6. Trio Stealth Pro 9.7" Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove 4 silver 4 cm Philips screws holding down the motherboard.
  7. Trio Stealth Pro 9.7" Motherboard Replacement: 步骤 7 中的图像 1,1
    • Cut red black and gray wires attached to the bottom of the motherboard connecting to the battery.
  8. Trio Stealth Pro 9.7" Motherboard Replacement: 步骤 8 中的图像 1,1
    • Cut three red and three black wires attached to the right side of the motherboard.
  9. Trio Stealth Pro 9.7" Motherboard Replacement: 步骤 9 中的图像 1,2 Trio Stealth Pro 9.7" Motherboard Replacement: 步骤 9 中的图像 2,2
    • Cut 4 wire cable attached to the right side of the motherboard.
    • Remove motherboard.
结论
2等其他人完成本指南。
Edward Insogna
于03/23/15注册
626 声望
创作了5篇指南
团队
UMass Dartmouth, Team 1-3, Miles Spring 2015 UMass Dartmouth, Team 1-3, Miles Spring 2015 的会员
UMASSD-MILES-S15S1G3
3 名成员
创作了10篇指南
1指南评论
We're can I get this motherboard
Heather carr - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 862
