跳转到主内容
加入维修社区 - 创建账户
Trio Stealth G4 Speaker Replacement
你所需要的
  1. Trio Stealth G4 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Working on your device while it is turned on may result in electric shock. Be sure to shut down and unplug your device before you begin.
    • Flip your tablet over so that the back panel is facing up.
  2. Trio Stealth G4 Speaker Replacement: 步骤 2 中的图像 1,2 Trio Stealth G4 Speaker Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to gently pry the back panel assembly apart from the front casing.
    • Start on one edge of the device by inserting the plastic opening tool between the back panel and the front casing using a gentle rocking motion.
  3. Trio Stealth G4 Speaker Replacement: 步骤 3 中的图像 1,1
    • Once you have successfully separated one edge of the back panel from the front casing, slide the plastic opening tool along the other edges to detach them as well.
    • The latches keeping the back panel attached to the front casing can sometimes be a little difficult to separate, so don't be afraid to use some force.
  4. Trio Stealth G4 Speaker Replacement: 步骤 4 中的图像 1,2 Trio Stealth G4 Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove the back panel from the rest of the tablet and set it aside.
  5. Trio Stealth G4 Speaker Replacement: 步骤 5 中的图像 1,1
    • The plastic volume button cover may fall out when you remove the back panel. Set it aside.
  6. Trio Stealth G4 Speaker Replacement, Speaker: 步骤 6 中的图像 1,2 Trio Stealth G4 Speaker Replacement, Speaker: 步骤 6 中的图像 2,2
    • Remove the yellow tape covering the set of wires located near the upper right corner of the battery.
  7. Trio Stealth G4 Speaker Replacement: 步骤 7 中的图像 1,2 Trio Stealth G4 Speaker Replacement: 步骤 7 中的图像 2,2
    • Use the soldering iron to melt away the solder from the red and black wires that connect the speaker to the motherboard.
    • Once the solder is completely removed, pull the wires away from the motherboard.
  8. Trio Stealth G4 Speaker Replacement: 步骤 8 中的图像 1,2 Trio Stealth G4 Speaker Replacement: 步骤 8 中的图像 2,2
    • Use a J000 Phillips head screwdriver to remove the two 4.3 mm screws securing the speaker to the device and set them aside.
  9. Trio Stealth G4 Speaker Replacement: 步骤 9 中的图像 1,3 Trio Stealth G4 Speaker Replacement: 步骤 9 中的图像 2,3 Trio Stealth G4 Speaker Replacement: 步骤 9 中的图像 3,3
    • Use your fingers to remove the plastic L-shaped speaker housing from the tablet.
结论
Matt Arnold
于09/22/15注册
607 声望
创作了5篇指南
团队
Baylor, Team 4-1, Williams Fall 2015 Baylor, Team 4-1, Williams Fall 2015 的会员
BU-WILLIAMS-F15S4G1
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 359
