简介
The speaker allows the device to play audio out loud. The replacement of the speaker may be necessary if your tablet does not play sound out loud, but still plays when headphones are plugged in.
The disassembly is relatively simple, but will require the use of a soldering iron to disconnect a couple of wires. Be sure to review the iFixit soldering guide if you do not have experience with soldering. You will also need to remove a couple of screws in order to take out the speaker.
你所需要的
Remove the yellow tape covering the set of wires located near the upper right corner of the battery.
Use the soldering iron to melt away the solder from the red and black wires that connect the speaker to the motherboard.
Once the solder is completely removed, pull the wires away from the motherboard.
