跳转到主内容
加入维修社区 - 创建账户
Trio Stealth G4 Motherboard Replacement
浏览量: 1383
浏览统计数据:
过去24小时
2
过去 7 天:
19
过去 30 天:
74
总计
1,383
评论: 0
暂时还没有人对本指南发表评论。你想做第一个评论的人吗?
Go to guide comments
已完成: 1
1 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 1
1 人收藏(并订阅)了本指南。你会是下一个吗?
所需时间: 20分钟
难度: 困难
The motherboard is the circuit that connects all of the parts within the tablet. It is essential to the proper function of the device. Damage to the motherboard often prevents the device from turning on or performing tasks correctly and usually requires that the motherboard be replaced. The most common cause of damage is exposure to water.
The disassembly is slightly more involved than the other replacement guides for this device. The use of a soldering iron is required to disconnect all of the wires connecting to the motherboard. Be sure to review the iFixit soldering guide if you do not have experience using a solder iron. You will also need to remove a couple of screws in order to take out the motherboard.
你所需要的
工具
    1. Trio Stealth G4 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Working on your device while it is turned on may result in electric shock. Be sure to shut down and unplug your device before you begin.
      • Flip your tablet over so that the back panel is facing up.
      询问修复机器人
      添加评论
    2. Trio Stealth G4 Motherboard Replacement: 步骤 2 中的图像 1,2 Trio Stealth G4 Motherboard Replacement: 步骤 2 中的图像 2,2
      • Use a plastic opening tool to gently pry the back panel assembly apart from the front casing.
      • Start on one edge of the device by inserting the plastic opening tool between the back panel and the front casing using a gentle rocking motion.
      询问修复机器人
      添加评论
    3. Trio Stealth G4 Motherboard Replacement: 步骤 3 中的图像 1,1
      • Once you have successfully separated one edge of the back panel from the front casing, slide the plastic opening tool along the other edges to detach them as well.
      • The latches keeping the back panel attached to the front casing can sometimes be a little difficult to separate, so don't be afraid to use some force.
      询问修复机器人
      添加评论
    4. Trio Stealth G4 Motherboard Replacement: 步骤 4 中的图像 1,2 Trio Stealth G4 Motherboard Replacement: 步骤 4 中的图像 2,2
      • Remove the back panel from the rest of the tablet and set it aside.
      询问修复机器人
      添加评论
    5. Trio Stealth G4 Motherboard Replacement: 步骤 5 中的图像 1,1
      • The plastic volume button cover may fall out when you remove the back panel. Set it aside.
      询问修复机器人
      添加评论
    1. Trio Stealth G4 Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,3 Trio Stealth G4 Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,3 Trio Stealth G4 Motherboard Replacement, Motherboard: 步骤 6 中的图像 3,3
      • Remove the 4 pieces of tape covering the zero insertion force (ZIF) connectors on the motherboard.
      询问修复机器人
      添加评论
    2. Trio Stealth G4 Motherboard Replacement: 步骤 7 中的图像 1,3 Trio Stealth G4 Motherboard Replacement: 步骤 7 中的图像 2,3 Trio Stealth G4 Motherboard Replacement: 步骤 7 中的图像 3,3
      • Use a spudger to flip up the black flaps on each of the 4 ZIF connectors.
      • Once the flaps are up, use your fingers to disconnect the end of the ribbon wires from the connectors.
      询问修复机器人
      添加评论
    3. Trio Stealth G4 Motherboard Replacement: 步骤 8 中的图像 1,2 Trio Stealth G4 Motherboard Replacement: 步骤 8 中的图像 2,2
      • Use the soldering iron to melt away the solder from each of the wires connecting to the motherboard.
      • Once the solder is completely removed, pull the wires away from the motherboard.
      询问修复机器人
      添加评论
    4. Trio Stealth G4 Motherboard Replacement: 步骤 9 中的图像 1,2 Trio Stealth G4 Motherboard Replacement: 步骤 9 中的图像 2,2
      • Use a J00 Phillips head screwdriver to remove the two 4.3 mm screws securing the motherboard to the device and set them aside.
      询问修复机器人
      添加评论
    5. Trio Stealth G4 Motherboard Replacement: 步骤 10 中的图像 1,1
      • Remove the silver piece of tape from the left edge of the motherboard.
      询问修复机器人
      添加评论
    6. Trio Stealth G4 Motherboard Replacement: 步骤 11 中的图像 1,2 Trio Stealth G4 Motherboard Replacement: 步骤 11 中的图像 2,2
      • Use a spudger to lift the motherboard from the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
作者
与
Matt Arnold
于09/22/15注册
607 声望
创作了5篇指南
团队
Baylor, Team 4-1, Williams Fall 2015 Baylor, Team 4-1, Williams Fall 2015 的会员
BU-WILLIAMS-F15S4G1
4 名成员
创作了60篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 74
总计 1,383
