跳转到主内容
Trackpad Prereq
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Trackpad Prereq, Unfasten the trackpad: 步骤 1 中的图像 1,2 Trackpad Prereq, Unfasten the trackpad: 步骤 1 中的图像 2,2
    • Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
    • Ten 5 mm screws
    • Three 5.8 mm screws
    • These screws all look similar—be careful not to mix them up.
    • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
    • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
  2. Trackpad Prereq, Remove the trackpad: 步骤 2 中的图像 1,3 Trackpad Prereq, Remove the trackpad: 步骤 2 中的图像 2,3 Trackpad Prereq, Remove the trackpad: 步骤 2 中的图像 3,3
    • Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
    • As you remove the trackpad assembly, be very careful not to lose the nine small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
    • Carefully feed the trackpad's ribbon cable through its slot in the frame.
  3. Trackpad Prereq: 步骤 3 中的图像 1,1
    • Remove the trackpad assembly.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 16" 2021 Answers community for help.
Alex Diaz-Kokaisl
于01/16/22注册
214,183 声望
创作了1,041篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 72
