跳转到主内容
加入维修社区 - 创建账户
Trackpad Cable Disconnect
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Trackpad Cable Disconnect, Prepare your Macbook Air for disassembly: 步骤 1 中的图像 1,3 Trackpad Cable Disconnect, Prepare your Macbook Air for disassembly: 步骤 1 中的图像 2,3 Trackpad Cable Disconnect, Prepare your Macbook Air for disassembly: 步骤 1 中的图像 3,3
    • Before you begin, discharge your battery below 25%, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power off your MacBook Air and unplug all cables.
    • Close the display and flip the laptop upside down. Keep the lid closed until you've physically disconnected the battery.
  2. Trackpad Cable Disconnect, Unfasten the lower case: 步骤 2 中的图像 1,2 Trackpad Cable Disconnect, Unfasten the lower case: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • Use a P5 Pentalobe driver to remove the four 6.4 mm screws securing the lower case:
    • Two screws with a short threaded portion near the hinges
    • Two screws with a long threaded portion near the front of the MacBook
  3. Trackpad Cable Disconnect, Insert an opening pick: 步骤 3 中的图像 1,3 Trackpad Cable Disconnect, Insert an opening pick: 步骤 3 中的图像 2,3 Trackpad Cable Disconnect, Insert an opening pick: 步骤 3 中的图像 3,3
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle with strong, steady force to create a small gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. Trackpad Cable Disconnect, Release the snapping clips: 步骤 4 中的图像 1,3 Trackpad Cable Disconnect, Release the snapping clips: 步骤 4 中的图像 2,3 Trackpad Cable Disconnect, Release the snapping clips: 步骤 4 中的图像 3,3
    • During the next two steps you'll feel and hear four snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next clip.
  5. Trackpad Cable Disconnect: 步骤 5 中的图像 1,3 Trackpad Cable Disconnect: 步骤 5 中的图像 2,3 Trackpad Cable Disconnect: 步骤 5 中的图像 3,3
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the two remaining snapping clips.
  6. Trackpad Cable Disconnect, Release the sliding tabs: 步骤 6 中的图像 1,3 Trackpad Cable Disconnect, Release the sliding tabs: 步骤 6 中的图像 2,3 Trackpad Cable Disconnect, Release the sliding tabs: 步骤 6 中的图像 3,3
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  7. Trackpad Cable Disconnect, Remove the lower case: 步骤 7 中的图像 1,3 Trackpad Cable Disconnect, Remove the lower case: 步骤 7 中的图像 2,3 Trackpad Cable Disconnect, Remove the lower case: 步骤 7 中的图像 3,3
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the four snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
  8. Trackpad Cable Disconnect, Remove the battery connector cover: 步骤 8 中的图像 1,1
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the battery connector cover.
  9. Trackpad Cable Disconnect: 步骤 9 中的图像 1,2 Trackpad Cable Disconnect: 步骤 9 中的图像 2,2
    • Remove the battery connector cover.
  10. Trackpad Cable Disconnect, Disconnect the battery: 步骤 10 中的图像 1,2 Trackpad Cable Disconnect, Disconnect the battery: 步骤 10 中的图像 2,2
    • Use an opening pick to pry up and disconnect the battery press connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  11. Trackpad Cable Disconnect, Unfasten the trackpad cable cover: 步骤 11 中的图像 1,1
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the trackpad cable cover.
  12. Trackpad Cable Disconnect, Access the trackpad press connector: 步骤 12 中的图像 1,2 Trackpad Cable Disconnect, Access the trackpad press connector: 步骤 12 中的图像 2,2
    • Use a spudger or your fingers to move the trackpad cable cover out of the way so you can access the press connector underneath.
  13. Trackpad Cable Disconnect, Disconnect the trackpad cable: 步骤 13 中的图像 1,2 Trackpad Cable Disconnect, Disconnect the trackpad cable: 步骤 13 中的图像 2,2
    • Use the pointed end of a spudger to pry up and disconnect the trackpad cable press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
结论
Spencer Day
于09/14/22注册
159,326 声望
创作了1,043篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,927篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 96
