跳转到主内容
Trackpad Cable Detachment
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Trackpad Cable Detachment, Prepare your Macbook Air for disassembly: 步骤 1 中的图像 1,3 Trackpad Cable Detachment, Prepare your Macbook Air for disassembly: 步骤 1 中的图像 2,3 Trackpad Cable Detachment, Prepare your Macbook Air for disassembly: 步骤 1 中的图像 3,3
    • Allow your MacBook's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully power off your MacBook.
    • Close the display and lay your MacBook upside down. Keep your laptop closed until you've physically disconnected the battery.
  2. Trackpad Cable Detachment, Unfasten the lower case: 步骤 2 中的图像 1,2 Trackpad Cable Detachment, Unfasten the lower case: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • Use a P5 pentalobe screwdriver to remove the four 6.4 mm‑long screws securing the lower case.
  3. Trackpad Cable Detachment, Insert an opening pick: 步骤 3 中的图像 1,3 Trackpad Cable Detachment, Insert an opening pick: 步骤 3 中的图像 2,3 Trackpad Cable Detachment, Insert an opening pick: 步骤 3 中的图像 3,3
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle to create a gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. Trackpad Cable Detachment, Release the snapping clips: 步骤 4 中的图像 1,3 Trackpad Cable Detachment, Release the snapping clips: 步骤 4 中的图像 2,3 Trackpad Cable Detachment, Release the snapping clips: 步骤 4 中的图像 3,3
    • During the next two steps you'll feel and hear six snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next two clips.
  5. Trackpad Cable Detachment: 步骤 5 中的图像 1,3 Trackpad Cable Detachment: 步骤 5 中的图像 2,3 Trackpad Cable Detachment: 步骤 5 中的图像 3,3
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the three remaining snapping clips.
  6. Trackpad Cable Detachment, Release the sliding tabs: 步骤 6 中的图像 1,3 Trackpad Cable Detachment, Release the sliding tabs: 步骤 6 中的图像 2,3 Trackpad Cable Detachment, Release the sliding tabs: 步骤 6 中的图像 3,3
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat to the frame and firmly slide it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  7. Trackpad Cable Detachment, Remove the lower case: 步骤 7 中的图像 1,3 Trackpad Cable Detachment, Remove the lower case: 步骤 7 中的图像 2,3 Trackpad Cable Detachment, Remove the lower case: 步骤 7 中的图像 3,3
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the six snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
  8. Trackpad Cable Detachment, Remove the battery connector cover tape: 步骤 8 中的图像 1,3 Trackpad Cable Detachment, Remove the battery connector cover tape: 步骤 8 中的图像 2,3 Trackpad Cable Detachment, Remove the battery connector cover tape: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    • Use blunt nose tweezers or your fingers to remove the piece of tape covering the battery connector cover.
    • During reassembly, use the leftover adhesive to secure the tape to the cover.
  9. Trackpad Cable Detachment, Remove the battery connector cover: 步骤 9 中的图像 1,3 Trackpad Cable Detachment, Remove the battery connector cover: 步骤 9 中的图像 2,3 Trackpad Cable Detachment, Remove the battery connector cover: 步骤 9 中的图像 3,3
    • Use a 3IP Torx Plus screwdriver to remove the two 1.5 mm‑long screws securing the battery connector cover.
    • Remove the cover.
  10. Trackpad Cable Detachment, Disconnect the battery: 步骤 10 中的图像 1,2 Trackpad Cable Detachment, Disconnect the battery: 步骤 10 中的图像 2,2
    • Use an opening pick to pry up and disconnect the battery connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  11. Trackpad Cable Detachment, Remove the trackpad cable tape: 步骤 11 中的图像 1,2 Trackpad Cable Detachment, Remove the trackpad cable tape: 步骤 11 中的图像 2,2
    • A small piece of black tape hides two trackpad cable cover screws.
    • Use tweezers or your fingers to remove the tape from the trackpad cable.
  12. Trackpad Cable Detachment, Separate the trackpad cable adhesive: 步骤 12 中的图像 1,2 Trackpad Cable Detachment, Separate the trackpad cable adhesive: 步骤 12 中的图像 2,2
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $2.99
    • Light adhesive secures the trackpad cable to its metal cover.
    • Pull the trackpad cable away from its cover to separate the adhesive securing it.
    • Use the leftover adhesive to secure the trackpad cable to the cover. If the cable doesn't stick, use double-sided tape to secure it.
    • If you have a replacement trackpad cable with adhesive pre-installed, remove the liner and press the cable into place.
  13. Trackpad Cable Detachment, Remove the trackpad cable cover: 步骤 13 中的图像 1,2 Trackpad Cable Detachment, Remove the trackpad cable cover: 步骤 13 中的图像 2,2
    • Use a 3IP Torx Plus screwdriver to remove the two 1.5 mm‑long screws securing the trackpad cable cover.
    • Remove the cover.
  14. Trackpad Cable Detachment, Disconnect the trackpad cable: 步骤 14 中的图像 1,2 Trackpad Cable Detachment, Disconnect the trackpad cable: 步骤 14 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the trackpad cable press connector from the logic board.
  15. Trackpad Cable Detachment, Heat the trackpad cable: 步骤 15 中的图像 1,1
    • Two small strips of adhesive secure the trackpad cable to the frame.
    • Heat an iOpener and apply it to the trackpad cable for two minutes to soften the adhesive securing it to the frame.
    • You can also use a hair dryer—but extreme heat can damage the battery, so proceed with care.
  16. Trackpad Cable Detachment, Separate the trackpad cable adhesive: 步骤 16 中的图像 1,3 Trackpad Cable Detachment, Separate the trackpad cable adhesive: 步骤 16 中的图像 2,3 Trackpad Cable Detachment, Separate the trackpad cable adhesive: 步骤 16 中的图像 3,3
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $2.99
    • Pull the trackpad cable toward the bottom of the MacBook to separate it from the frame.
    • If you have a replacement trackpad cable with adhesive pre-installed, remove the liners and press the cable into place.
结论
Spencer Day
于09/14/22注册
155,809 声望
创作了1,033篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,828篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 65
