简介
你有没有想过如何对自己的车进行基本保养?
这本指南甚至教会最笨拙的工匠如何只用几个基本工具来更换自己的机油。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Pull the hood release latch. The latch is located inside of the car under the steering wheel.
Pull the hood release. The release is located under the front center of the hood.
Use the hood support rod to keep the hood propped up. The rod is located along the front edge of the engine compartment.
这个步骤还没有翻译 帮忙翻译一下
Set the torque wrench to 32 ft-lbs.
Check if all of the oil has drained from the engine by seeing if the oil is still flowing into the drain pan.
Wipe any spills on the ground.
Replace the drain plug.
Use the 14mm socket torque wrench to tighten the drain plug until the wrench makes a "clicking" noise.
这个步骤还没有翻译 帮忙翻译一下
Start the truck and let it run for 5 minutes before turning off the engine.
Locate the engine dipstick. The dipstick is located on the left side of the engine compartment and is designated by a yellow ring.
Remove the dipstick and wipe it clean.
Reinsert and remove the dipstick to see if the oil is between the two dots on the dipstick.
要重新组装设备,请按照相反的顺序执行这些说明。
13等其他人完成本指南。
由衷感谢以下译者:
46%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
6条评论
Can you show me the 2007 Toyota Tacoma Oil Change also ?
This is not applicable to the 2019 (and probably later) models. They now use canister filters located under the skid plate.
