跳转到主内容
Toyota Tacoma Oil Change
你所需要的
  1. Toyota Tacoma Oil Change, Toyota Tacoma Oil Change: 步骤 1 中的图像 1,1
    • Locate the oil drain plug. The plug is located underneath the front of the truck on the bottom of the engine crank case.
    • Warm up the engine by letting it run or driving it for 10-20 minutes to ensure the oil will flow easily.
    • Be careful not to touch the engine as it will be hot.
  2. Toyota Tacoma Oil Change: 步骤 2 中的图像 1,1
    • Place the drain pan under the drain plug so it will catch the oil as it falls vertically from the engine.
  3. Toyota Tacoma Oil Change: 步骤 3 中的图像 1,1
    • Loosen the drain plug by turning the 14mm socket counterclockwise.
    • Avoid getting oil on the ground by moving the oil pan accordingly.
    • Move your hand away from under the drain plug quickly after loosening it to avoid getting hot oil on your hand.
  4. Toyota Tacoma Oil Change: 步骤 4 中的图像 1,3 Toyota Tacoma Oil Change: 步骤 4 中的图像 2,3 Toyota Tacoma Oil Change: 步骤 4 中的图像 3,3
    • Pull the hood release latch. The latch is located inside of the car under the steering wheel.
    • Pull the hood release. The release is located under the front center of the hood.
    • Use the hood support rod to keep the hood propped up. The rod is located along the front edge of the engine compartment.
  5. Toyota Tacoma Oil Change: 步骤 5 中的图像 1,2 Toyota Tacoma Oil Change: 步骤 5 中的图像 2,2
    • Locate the oil filter in the engine compartment. The oil filter is on the lower right side of the engine.
    • Remove the filter by turning it counterclockwise with a wrench .
    • The wrench wraps around the filter and tightens itself as you turn it counterclockwise.
    • Use force if the filter is difficult to remove.
    • The oil filter may be hot.
  6. Toyota Tacoma Oil Change: 步骤 6 中的图像 1,2 Toyota Tacoma Oil Change: 步骤 6 中的图像 2,2
    • Apply a small amount of fresh oil to the edge of the new filter.
    • Use your hand to tighten the new filter until it fits snugly.
    • As the engine runs, it will cause the filter to tighten itself, so it is unnecessary to use additional force to tighten the filter.
  7. Toyota Tacoma Oil Change: 步骤 7 中的图像 1,3 Toyota Tacoma Oil Change: 步骤 7 中的图像 2,3 Toyota Tacoma Oil Change: 步骤 7 中的图像 3,3
    • Set the torque wrench to 32 ft-lbs.
    • Check if all of the oil has drained from the engine by seeing if the oil is still flowing into the drain pan.
    • Wipe any spills on the ground.
    • Replace the drain plug.
    • Use the 14mm socket torque wrench to tighten the drain plug until the wrench makes a "clicking" noise.
    • Do not over tighten the drain plug with the torque wrench. Too much force could cause the head of the bolt to snap off and become stuck in the engine.
  8. Toyota Tacoma Oil Change: 步骤 8 中的图像 1,1
    • Locate the oil fill cap in the engine compartment. The cap is located on the lower right side of the engine next to the oil filter.
    • Remove the cap by unscrewing it counterclockwise.
  9. Toyota Tacoma Oil Change: 步骤 9 中的图像 1,1
    • Place the funnel into the oil fill tube.
    • Pour 5 quarts of new oil into the funnel.
    • Replace the oil fill cap.
  10. Toyota Tacoma Oil Change: 步骤 10 中的图像 1,2 Toyota Tacoma Oil Change: 步骤 10 中的图像 2,2
    • Start the truck and let it run for 5 minutes before turning off the engine.
    • Locate the engine dipstick. The dipstick is located on the left side of the engine compartment and is designated by a yellow ring.
    • Remove the dipstick and wipe it clean.
    • Reinsert and remove the dipstick to see if the oil is between the two dots on the dipstick.
    • The job is finished if the oil is between or slightly above the two dots.
    • If the oil is below the two dots, add new oil in small increments into the oil fill tube until the dipstick shows it is between the two dots.
    • Do not pour oil into the dipstick tube.
结论
13等其他人完成本指南。
Eric Rodan
于02/24/15注册
369 声望
撰写一个指南
团队
Cal Poly, Team 23-2, Green Winter 2015 Cal Poly, Team 23-2, Green Winter 2015 的会员
CPSU-GREEN-W15S23G2
4 名成员
创作了16篇指南
6条评论
Can you show me the 2007 Toyota Tacoma Oil Change also ?
Virgilio Pilapil - 回复
Step 3 Don’t spill the oil on the ground (pic shows a puddle of oil on the ground).
wislofsky - 回复
Can you use a EWK 6.5L Pneumatic Manual Oil Extractor Pump Vacuum Fluid Evacuator Motor Engine Oil Changer with a 2009 Tacoma?
TJQP - 回复
Can you use EWK 6.5L Pneumatic Manual Oil Extractor Pump Vacuum Fluid Evacuator Motor Engine Oil Changer on a 2009 Tacoma, or any Toyota?
TJQP - 回复
This is not applicable to the 2019 (and probably later) models. They now use canister filters located under the skid plate.
Red Fummoxed - 回复
添加评论
浏览统计数据:
过去 24 小时: 27
过去 7 天: 179
过去 30 天: 923
总计 148,143
