简介
This guide will show you how to replace the CPU fan and heat sink of the Toshiba Tetra Z50-A.
The CPU fan blows and pulls air off the CPU, keeping it from over heating. This replacement may be needed to fix issues such as overheating, frequent crashing, error messages, or your device making unusual or loud noises. In some cases the CPU can be damaged or broken. Before using this guide, check the trouble shooting page for any other issues that might cause similar problems.
Keep in mind for this guide you will need to know how to apply Thermal Paste to your device. Make sure to completely power of the device and disconnect any power sources before starting this guide.
你所需要的
Turn off the laptop.
Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
Remove the four 3 mm screws from the heat sink using a Phillips #0 screwdriver.
另外一个人完成了本指南。
