跳转到主内容
Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement
你所需要的
  1. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: 步骤 2 中的图像 1,1
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement, Battery: 步骤 3 中的图像 1,1
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: 步骤 4 中的图像 1,1
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: 步骤 5 中的图像 1,1
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: 步骤 6 中的图像 1,1
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: 步骤 7 中的图像 1,1
    • Lift up on the battery with your hands and remove it from the laptop.
  8. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement, CPU Fan and Heat Sink: 步骤 8 中的图像 1,1
    • Remove the four 3 mm screws from the heat sink using a Phillips #0 screwdriver.
  9. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: 步骤 9 中的图像 1,1
    • Remove the two 4 mm screws from the fan using a Phillips #0 screwdriver.
  10. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: 步骤 10 中的图像 1,1
    • Remove the heat sink from the laptop.
  11. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: 步骤 11 中的图像 1,1
    • Pull towards the bottom of the laptop to disconnect the fan cable from its connector on the motherboard.
  12. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: 步骤 12 中的图像 1,1
    • Lift up on the fan and remove it from the laptop.
    • When replacing the fan and heat sink, be sure to reapply thermal paste.
结论
另外一个人完成了本指南。
Luis Juen Baez
于10/25/21注册
585 声望
创作了4篇指南
团队
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 的会员
UMASSD-SINCLAIRE-F21S2G4
3 名成员
创作了21篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 14
总计 380
