跳转到主内容
Toshiba Tecra Z50-A Battery Replacement
你所需要的
  1. Toshiba Tecra Z50-A Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A Battery Replacement: 步骤 2 中的图像 1,1
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A Battery Replacement: 步骤 4 中的图像 1,1
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A Battery Replacement: 步骤 7 中的图像 1,1
    • Lift up on the battery with your hands and remove it from the laptop.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
另外一个人完成了本指南。
Dominic Hryzan
于10/25/21注册
545 声望
创作了3篇指南
团队
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 的会员
UMASSD-SINCLAIRE-F21S2G4
3 名成员
创作了21篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 29
总计 919
