跳转到主内容
Toshiba Satellite P855-S5102 Keyboard Replacement
你所需要的
  1. Toshiba Satellite P855-S5102 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Toshiba Satellite P855-S5102 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Use a plastic opening tool to pry up the keyboard cover.
  2. Toshiba Satellite P855-S5102 Keyboard Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite P855-S5102 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry up the keyboard.
  3. Toshiba Satellite P855-S5102 Keyboard Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite P855-S5102 Keyboard Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite P855-S5102 Keyboard Replacement: 步骤 3 中的图像 3,3
    • Lay the keyboard upright against the screen.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Remove the ribbon cable from the socket.
结论
另外一个人完成了本指南。
Benson Smith
于01/25/18注册
351 声望
创作了3篇指南
团队
USF Tampa, Team S20-G3, Passmore Spring 2018 USF Tampa, Team S20-G3, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S20G3
4 名成员
创作了7篇指南
一条评论
Proceeding this way you will get to break all seals that join that “cover“ to the rest of the keyboard assembly, rendering it unusable if you were not replacing it (in the “step 2“ photos you get to see all the broken pins where the joined parts used to be). In fact, you have to proceed from the other side and remove the cover from under the computer, there you’ll find some small tabs towards the touchpad end of things, you gently pry each tab while loosening that side of the keyboard and it rises up. Be careful not to break the flex circuit that joins it to the mainboard in the process.
Kenneth - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 8
总计 407
