跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
The keyboard is the part of the computer that lets you enter data into it. If the keyboard is sticking or not functioning properly it will be hard to enter data. Below are a few steps on how to remove the keyboard.
配件
没有特定配件。
  1. Use a plastic opening tool to pry up the keyboard cover. Use a plastic opening tool to pry up the keyboard cover.
    • Use a plastic opening tool to pry up the keyboard cover.
  2. Use a plastic opening tool to pry up the keyboard. Use a plastic opening tool to pry up the keyboard.
    • Use a plastic opening tool to pry up the keyboard.
  3. Lay the keyboard upright against the screen. Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket. Remove the ribbon cable from the socket.
    • Lay the keyboard upright against the screen.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Remove the ribbon cable from the socket.
结论
Benson Smith
于2018年01月25日注册
327 信誉积分
创作了3篇指南
团队
USF Tampa, Team S20-G3, Passmore Spring 2018 USF Tampa, Team S20-G3, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S20G3
4 名成员
创作了7篇指南
Proceeding this way you will get to break all seals that join that “cover“ to the rest of the keyboard assembly, rendering it unusable if you were not replacing it (in the “step 2“ photos you get to see all the broken pins where the joined parts used to be). In fact, you have to proceed from the other side and remove the cover from under the computer, there you’ll find some small tabs towards the touchpad end of things, you gently pry each tab while loosening that side of the keyboard and it rises up. Be careful not to break the flex circuit that joins it to the mainboard in the process.
Kenneth - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 7
总计 103
