跳转到主内容
Toshiba Satellite P55-A5312 CD Drive Replacement
你所需要的
  1. Toshiba Satellite P55-A5312 CD Drive Replacement, CD Drive: 步骤 1 中的图像 1,2 Toshiba Satellite P55-A5312 CD Drive Replacement, CD Drive: 步骤 1 中的图像 2,2
  2. Toshiba Satellite P55-A5312 CD Drive Replacement: 步骤 2 中的图像 1,1
    • Locate the CD drive at the lower right hand corner of the laptop.
    • Unscrew any screws that are holding the drive in place. However, there should only be one. The other screws holding the drive in place are also responsible for holding the bottom casing.
  3. Toshiba Satellite P55-A5312 CD Drive Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite P55-A5312 CD Drive Replacement: 步骤 3 中的图像 2,2
    • Carefully remove the CD drive by pulling it from its connection to the motherboard.
    • Replace it by inserting a new CD drive and replacing any screws you have removed.
结论
ohatae
于01/25/17注册
294 声望
创作了2篇指南
团队
Cal Poly, Team 9-1, Banghart Winter 2017 Cal Poly, Team 9-1, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S9G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 726
