跳转到主内容
Toshiba Satellite P55-A5312 Disassembly
你所需要的
  1. Toshiba Satellite P55-A5312 Disassembly, Toshiba Satellite P55-A5312 Disassembly: 步骤 1 中的图像 1,2 Toshiba Satellite P55-A5312 Disassembly, Toshiba Satellite P55-A5312 Disassembly: 步骤 1 中的图像 2,2
    • Locate all rubber plugs on the bottom of the laptop. These will need to be removed with a pointed object like the Spudger.
  2. Toshiba Satellite P55-A5312 Disassembly: 步骤 2 中的图像 1,1
    • After all rubber plugs are removed, use a Phillip's head screw driver to unscrew all previously covered screws.
  3. Toshiba Satellite P55-A5312 Disassembly: 步骤 3 中的图像 1,2 Toshiba Satellite P55-A5312 Disassembly: 步骤 3 中的图像 2,2
    • After all screws have been removed, pry the bottom cover of your laptop starting at the front edge.
    • Slowly work your way around the laptop until the back cover is completely off.
结论
另外一个人完成了本指南。
Jordan Kochavi
于01/25/17注册
300 声望
创作了2篇指南
团队
Cal Poly, Team 9-1, Banghart Winter 2017 Cal Poly, Team 9-1, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S9G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 22
总计 4,868
