跳转到主内容
Toshiba Satellite P55-A5312 Battery Replacement
你所需要的
  1. Toshiba Satellite P55-A5312 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite P55-A5312 Battery Replacement, Battery: 步骤 1 中的图像 2,2
  2. Toshiba Satellite P55-A5312 Battery Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite P55-A5312 Battery Replacement: 步骤 2 中的图像 2,2
    • Locate the battery, which is in the top right hand corner of the laptop.
    • Remove all the 2.5x6mm screws that secure the battery with a Philips 00 screwdriver.
  3. Toshiba Satellite P55-A5312 Battery Replacement: 步骤 3 中的图像 1,1
    • Locate the intersection of the wires that connect the battery to the motherboard.
    • Unplug these wires by gently pulling on the white plug, as shown in the picture.
  4. Toshiba Satellite P55-A5312 Battery Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the speaker that is placed above the battery by gently pulling upward from one end. Be careful not to break a wire.
    • Move the speaker elsewhere while replacing the battery (do not disconnect it).
  5. Toshiba Satellite P55-A5312 Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the battery from the laptop after it has been completely disconnected.
结论
5等其他人完成本指南。
ohatae
于01/25/17注册
294 声望
创作了2篇指南
团队
Cal Poly, Team 9-1, Banghart Winter 2017 Cal Poly, Team 9-1, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S9G1
3 名成员
创作了6篇指南
一条评论
The repair guide was great. Got right through the battery change procedure. only took about 25 minutes start to finish. I was told by a friend to try this as a way to bypass the forgotten password at startup of the computer so that I could put a new password in it. The result is that did not work. Can anybody tell me how to do this
Roy Conrad - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 23
总计 5,824
