简介
This guide shows you how to replace the Toshiba Satellite L670 HDD.
你所需要的
Turn the laptop upside down. Locate the two latches on either side of the battery.
Now the battery comes off.
Pull the HDD to the left using the silver tab.
Pull up on the silver tab and remove the hard drive from the slot.
Take your new SSD hard drive.
Place the SSD in the silver case.
Place back the 4 screws you just removed.
Replace the back panel and screw it in place.
Put the battery back in, you will hear a click once it falls into place.
To reassemble the device, follow these instructions in reverse order.
另外一个人完成了本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
