简介
This guide will instruct you on how to safely remove and replace the speakers of your Toshiba Satellite L55W-C5256. You may need to do this if:
- Your device’s speakers are “blown”, or are emitting crackling noises
- Your device is not outputting any audio
Before beginning this replacement guide, it is recommended that you use an anti-static work mat and that you ground yourself using an anti-static wrist strap. This helps to protect your device from damage caused by static discharge. If you do not have these materials, you can find an anti-static wrist strap here, and an anti-static work mat here. To learn how to properly use an anti-static wrist strap and an anti-static work mat (recommended), see the guide found here.
你所需要的
Using a Phillips #00 screw driver, remove the four 7.0 mm screws that secure the heat sink to the CPU.
Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the left speaker to the motherboard.
Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the right speaker to the motherboard.
另外一个人完成了本指南。
