跳转到主内容
Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement
你所需要的
  1. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement, Battery: 步骤 1 中的图像 3,3
    • Unlock the battery by sliding the left battery latch to the right.
    • To remove the battery, hold the spring-loaded right battery latch to the right, then grasp the center battery tab and pull upward.
  2. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement, CPU thermal paste: 步骤 2 中的图像 1,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement, CPU thermal paste: 步骤 2 中的图像 2,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement, CPU thermal paste: 步骤 2 中的图像 3,3
    • Use a Phillips #00 screwdriver to loosen the RAM cover and 2.5 inch HDD cover captive screws.
  3. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 3 中的图像 3,3
    • Gently pull the caddy pull strap outwards then upwards to remove the HDD assembly.
    • Do not immediately pull upwards on the HDD, as this will bend the connector resulting in damage.
  4. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the M2.5x6 optical drive retaining screw.
  5. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 5 中的图像 2,2
    • Locate the gray optical drive screw bracket, then gently push outwards to release the optical drive.
    • Grasp the edge of the optical drive and pull outwards to remove it from the device.
    • The optical drive bracket is tucked underneath the bottom chassis cover where the optical drive screw hole is located.
  6. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 6 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the twelve M2.5x6 bottom chassis screws.
  7. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 7 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the three M2x3 inner battery compartment screws.
  8. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 8 中的图像 2,2
    • Place the device keyboard side up, then use an opening tool to gently remove the top keyboard bezel.
    • To prevent damage to the plastic clips, pry the keyboard bezel up at a shallow angle until the entire assembly is free.
  9. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 9 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the two M2x3 keyboard retaining screws.
  10. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 10 中的图像 1,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 10 中的图像 2,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 10 中的图像 3,3
    • Lift the top of the keyboard up and towards the front of the device, then gently pull backwards to release the bottom of the keyboard.
    • Do not immediately pull the keyboard away, as this will damage the ribbon cable underneath.
    • Gently pull the ribbon cable out of its connector to release the keyboard.
    • To reconnect the ribbon cable, align the connector parallel to the socket, then gently push the connector into the socket.
  11. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 11 中的图像 1,2 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 11 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the five M2.5x6 top cover screws
  12. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 12 中的图像 1,2 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 12 中的图像 2,2
    • Use tweezers to gently pull and unplug the touchpad ribbon cable.
    • Unplug the speaker connector by gently prying both ends with the tweezer until the connector comes loose.
    • To reconnect the touchpad, hold the black plastic tab with tweezers or a finger, then align the connector parallel to the socket. This prevents the cable from flexing as it is inserted into the socket.
  13. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 13 中的图像 1,2 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 13 中的图像 2,2
    • Begin removing the top cover by gently prying apart the right side using the opening tool. Start by finding a gap near the empty DVD drive bay.
    • The right side is free when the top cover sits loosely above the bottom cover.
  14. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 14 中的图像 1,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 14 中的图像 2,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 14 中的图像 3,3
    • To release the front of the top cover, use an opening tool or a spudger to pry around the two lid latch holes at the front of the device, starting from the right side.
    • To prevent damage to the front volume wheel and SD card reader, ensure the opening tool does not reach into those areas.
  15. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 15 中的图像 1,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 15 中的图像 2,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 15 中的图像 3,3
    • Finish releasing the top cover by prying the left side, first above the USB ports, then near the rear hinge.
  16. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 16 中的图像 1,2 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 16 中的图像 2,2
    • Grab the front of the top cover, push backwards slightly to ensure the rear hinge clips are free, then pull up and towards the front of the device to remove the top cover.
  17. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 17 中的图像 1,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 17 中的图像 2,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 17 中的图像 3,3
    • Using fingers or tweezers, unplug the display ribbon cable and DC power cable.
    • Take a picture to remember cable layout and routing for reassembly.
  18. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 18 中的图像 1,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 18 中的图像 2,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 18 中的图像 3,3
    • Using fingers or tweezers, unplug the USB port cable and microphone wire.
  19. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 19 中的图像 1,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 19 中的图像 2,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 19 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the two M2x3 modem card screws.
    • Pull upwards on the modem card to release it from the press-fit connector.
  20. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 20 中的图像 1,1
    • Using tweezers, gently pull upwards and unplug the wireless card antenna wires from the coaxial connectors.
    • To reassemble, use tweezers to hold the wire terminal directly over the card connector, then press downwards. A misaligned connector could bend the center pin, resulting in damage.
  21. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 21 中的图像 1,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 21 中的图像 2,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 21 中的图像 3,3
    • Using fingers or tweezers, unplug the power button cable and webcam cable.
  22. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 22 中的图像 1,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 22 中的图像 2,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 22 中的图像 3,3
    • Before removing the motherboard from the chassis, ensure all wires are tucked away to prevent snagging.
    • Use a Phillips #00 screwdriver to remove the two M2.5x6 motherboard screws.
  23. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 23 中的图像 1,2 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 23 中的图像 2,2
    • Grab the top of the motherboard, then pull upwards and towards the back of the device to remove the motherboard.
    • Do not immediately pull the motherboard upwards, as the front volume wheel and SD card reader will get caught on the bottom chassis, resulting in damage.
    • Lay the motherboard on a clean flat surface so that the CPU cooler is visible, as shown in the second picture.
  24. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 24 中的图像 1,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 24 中的图像 2,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 24 中的图像 3,3
    • Using a 2mm Phillips screwdriver, remove the 2 M2x3 CPU fan screws.
    • Using tweezers, gently unplug the CPU fan cable, then remove the CPU fan from the cooler.
    • There may be significant dust build up between the fan and cooler. Use a soft brush or compressed air to remove the dust.
  25. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 25 中的图像 1,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 25 中的图像 2,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 25 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the two M2x3 heat sink bracket screws.
  26. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 26 中的图像 1,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 26 中的图像 2,3 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 26 中的图像 3,3
    • Remove the CPU cooler and place it with the copper heat plates facing upwards.
    • Wet the paper towel with high concentration Isopropyl Alcohol, then proceed to wipe away any old thermal paste on the copper heat plate.
    • Using a new piece of paper towel, wet with Isopropyl alcohol and wipe away any old thermal paste on the CPU die.
    • Do not touch the exposed CPU die with fingers. Body oil will negatively affect thermal transfer between the CPU and cooler.
    • If unsure on how to perform this step, please see the guide on how to clean and apply thermal paste.
  27. Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 27 中的图像 1,2 Toshiba Satellite L300-04P (PSLB8C-04P01X) CPU Thermal Paste Replacement: 步骤 27 中的图像 2,2
    • Ensure the CPU and cooler are both free of any residue and completely dry of Isopropyl alcohol.
    • Next to the CPU is the integrated GPU, covered by a thermal pad. If this pad is stuck to the CPU cooler, use a spudger to carefully remove the pad from the cooler and place it over the integrated GPU as shown in the first picture.
    • Using the thermal paste, apply a small, pea-sized drop directly over the CPU.
    • When reassembling, align the CPU cooler then press down evenly to ensure the thermal paste is evenly spread for best thermal performance.
结论
Nathan L
于01/17/23注册
373 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 31
总计 295
