跳转到主内容
Toshiba Satellite E45-B4200 Heat Sink Replacement
你所需要的
  1. Toshiba Satellite E45-B4200 Heat Sink Replacement, Back Case: 步骤 1 中的图像 1,3 Toshiba Satellite E45-B4200 Heat Sink Replacement, Back Case: 步骤 1 中的图像 2,3 Toshiba Satellite E45-B4200 Heat Sink Replacement, Back Case: 步骤 1 中的图像 3,3
    • Make sure to turn off the device, remove the battery, and unplug the laptop from the charger prior to the disassembly.
    • Use a Phillips #0 screwdriver to remove fourteen 3.75 mm screws from the back cover.
    • Use a spudger or opening tool to gently separate the back cover from the top of the device. Work your way around the perimeter of the laptop and undo the clips with the spudger.
    • Remove the back case.
  2. Toshiba Satellite E45-B4200 Heat Sink Replacement, Heat Sink: 步骤 2 中的图像 1,1
    • Locate the heat sink system in the middle of the motherboard, resembling a copper strip.
  3. Toshiba Satellite E45-B4200 Heat Sink Replacement: 步骤 3 中的图像 1,1
    • Using a #0 Phillips screwdriver, unscrew the heat sink attached to the processor.
    • This is located at the center of the motherboard.
  4. Toshiba Satellite E45-B4200 Heat Sink Replacement: 步骤 4 中的图像 1,1
    • Lift the heat sink system off the processor.
    • Apply fresh thermal paste to the CPU before placing a new heatsink in the device.
结论
Raymond Makynen
于03/20/23注册
289 声望
创作了3篇指南
团队
UMass Dartmouth, Team 5-2, Ramos Spring 2023 UMass Dartmouth, Team 5-2, Ramos Spring 2023 的会员
UMASSD-RAMOS-S23S5G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 118
