跳转到主内容
Toshiba Chromebook 2 Motherboard Replacement
你所需要的
  1. Toshiba Chromebook 2 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Motherboard Replacement: 步骤 3 中的图像 1,2 Toshiba Chromebook 2 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Motherboard Replacement: 步骤 4 中的图像 1,2 Toshiba Chromebook 2 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,2 Toshiba Chromebook 2 Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Remove the 14 Phillips 2.34mm screws using the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the metal plate covering the motherboard by lifting it vertically.
  8. Toshiba Chromebook 2 Motherboard Replacement: 步骤 8 中的图像 1,3 Toshiba Chromebook 2 Motherboard Replacement: 步骤 8 中的图像 2,3 Toshiba Chromebook 2 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Flip up the plastic clamps holding down the 4 ribbon cables connected to the motherboard while gently pulling the ribbon cables from the sockets.
  9. Toshiba Chromebook 2 Motherboard Replacement: 步骤 9 中的图像 1,3 Toshiba Chromebook 2 Motherboard Replacement: 步骤 9 中的图像 2,3 Toshiba Chromebook 2 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Use the spudger to press down on the 2 white port cables, while also pulling each white port cable out of their sockets.
  10. Toshiba Chromebook 2 Motherboard Replacement: 步骤 10 中的图像 1,3 Toshiba Chromebook 2 Motherboard Replacement: 步骤 10 中的图像 2,3 Toshiba Chromebook 2 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Disconnect the motherboard from the 3 remaining cables by pulling the chords out of the sockets.
  11. Toshiba Chromebook 2 Motherboard Replacement: 步骤 11 中的图像 1,2 Toshiba Chromebook 2 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Remove the motherboard by pulling upward and to the right.
    • Be careful not to damage the ports located on the left side of the motherboard during removal.
结论
2等其他人完成本指南。
Sam Nishi
于10/06/16注册
485 声望
撰写一个指南
团队
Cal Poly, Team 10-4, Livingston Fall 2016 Cal Poly, Team 10-4, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S10G4
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 2,857
