跳转到主内容
加入维修社区 - 创建账户
Top Shield Plate Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Top Shield Plate Removal, Prepare your PlayStation for disassembly: 步骤 1 中的图像 1,3 Top Shield Plate Removal, Prepare your PlayStation for disassembly: 步骤 1 中的图像 2,3 Top Shield Plate Removal, Prepare your PlayStation for disassembly: 步骤 1 中的图像 3,3
    • Before starting your repair:
    • Shut down your console and unplug all cables and accessories.
    • Remove any stands supporting your device and lay it down.
  2. Top Shield Plate Removal, Remove the console covers: 步骤 2 中的图像 1,3 Top Shield Plate Removal, Remove the console covers: 步骤 2 中的图像 2,3 Top Shield Plate Removal, Remove the console covers: 步骤 2 中的图像 3,3
    • Each console cover is secured with hooks along the rear edge and clips along the front edge.
    • To remove a cover, firmly pull up the front edge to release the clips.
    • You'll hear distinct "pops" as the clips release.
    • Remove the cover.
  3. Top Shield Plate Removal: 步骤 3 中的图像 1,3 Top Shield Plate Removal: 步骤 3 中的图像 2,3 Top Shield Plate Removal: 步骤 3 中的图像 3,3
    • Use the same process to remove the three remaining covers.
    • To reinstall a cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the clips.
  4. Top Shield Plate Removal, Remove the disc drive: 步骤 4 中的图像 1,3 Top Shield Plate Removal, Remove the disc drive: 步骤 4 中的图像 2,3 Top Shield Plate Removal, Remove the disc drive: 步骤 4 中的图像 3,3
    • If your PlayStation doesn't have a disc drive, skip this step.
    • Use the cutout on the bottom right corner of the disc drive to lift its right edge and disconnect it.
    • Remove the disc drive.
    • During reassembly, place the hooks on the left edge of the drive into their cutouts and firmly press the drive into place so the connector on the bottom right corner goes into its socket.
  5. Top Shield Plate Removal, Remove the expansion slot cover screws: 步骤 5 中的图像 1,2 Top Shield Plate Removal, Remove the expansion slot cover screws: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • Use a Phillips screwdriver to remove the 17.1 mm‑long screw securing the expansion slot cover.
  6. Top Shield Plate Removal, Remove the expansion slot cover: 步骤 6 中的图像 1,3 Top Shield Plate Removal, Remove the expansion slot cover: 步骤 6 中的图像 2,3 Top Shield Plate Removal, Remove the expansion slot cover: 步骤 6 中的图像 3,3
    • Use your fingers to lift the expansion slot cover near the notch by the screw hole and remove it.
  7. Top Shield Plate Removal, Remove the fan cables cover: 步骤 7 中的图像 1,3 Top Shield Plate Removal, Remove the fan cables cover: 步骤 7 中的图像 2,3 Top Shield Plate Removal, Remove the fan cables cover: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $8.95
    • Use your fingers to remove the plastic cover hiding the fan cables connector.
    • The cover is secured with light adhesive.
    • During reassembly, press the piece of plastic back into place to secure it with the leftover adhesive. If it isn't sticking, use strips of double-sided tape to secure it.
  8. Top Shield Plate Removal, Free the fan cables: 步骤 8 中的图像 1,2 Top Shield Plate Removal, Free the fan cables: 步骤 8 中的图像 2,2
    • Gently pull the fan cables out from under their plastic clip on the frame.
  9. Top Shield Plate Removal, Disconnect the fan: 步骤 9 中的图像 1,3 Top Shield Plate Removal, Disconnect the fan: 步骤 9 中的图像 2,3 Top Shield Plate Removal, Disconnect the fan: 步骤 9 中的图像 3,3
    • Firmly grip the fan cables white connector head and pull it straight up and out of its socket.
    • If you're having trouble, grip the cables just above the connector head, and gently pull.
    • During reassembly, align the connector over its socket and push down on the edges with the flat end of a spudger until it slides fully into its socket.
  10. Top Shield Plate Removal, Remove the fan screws: 步骤 10 中的图像 1,2 Top Shield Plate Removal, Remove the fan screws: 步骤 10 中的图像 2,2
    • Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
    • One 31.2 mm‑long screw
    • Two 21.3 mm‑long screws
    • One 11.6 mm‑long screw
  11. Top Shield Plate Removal, Remove the fan: 步骤 11 中的图像 1,2 Top Shield Plate Removal, Remove the fan: 步骤 11 中的图像 2,2
    • Use your fingers to grab the fan by its vents, and lift it straight up to remove it.
    • During reassembly:
    • This is a good point to clean the fan. Use a clean cloth and some compressed air to remove any dust or dirt.
    • Insert the fan so its cables are near their connector.
  12. Top Shield Plate Removal, Peel up the tamper evident sticker: 步骤 12 中的图像 1,3 Top Shield Plate Removal, Peel up the tamper evident sticker: 步骤 12 中的图像 2,3 Top Shield Plate Removal, Peel up the tamper evident sticker: 步骤 12 中的图像 3,3
    在这个步骤中使用的工具:
  13. Top Shield Plate Removal, Remove the main board cover screws: 步骤 13 中的图像 1,2 Top Shield Plate Removal, Remove the main board cover screws: 步骤 13 中的图像 2,2
    • Use a T8 Torx Security screwdriver to remove the nine screws securing the main board cover:
    • Four 18.9 mm‑long screws
    • One 21.3 mm‑long screw
    • Four 31.2 mm‑long screws
  14. Top Shield Plate Removal, Remove the main board cover: 步骤 14 中的图像 1,2 Top Shield Plate Removal, Remove the main board cover: 步骤 14 中的图像 2,2
    • Lift the main board cover straight up and remove it.
  15. Top Shield Plate Removal, Remove the interconnect cable cover screws: 步骤 15 中的图像 1,2 Top Shield Plate Removal, Remove the interconnect cable cover screws: 步骤 15 中的图像 2,2
    • Use a T8 Torx Security screwdriver to remove the four screws securing the interconnect cable cover:
    • One 28.7 mm‑long screw
    • Three 7.5 mm‑long screws
  16. Top Shield Plate Removal, Remove the interconnect cable cover: 步骤 16 中的图像 1,2 Top Shield Plate Removal, Remove the interconnect cable cover: 步骤 16 中的图像 2,2
    • Remove the interconnect cable cover.
  17. Top Shield Plate Removal, Disconnect the interconnect cable: 步骤 17 中的图像 1,3 Top Shield Plate Removal, Disconnect the interconnect cable: 步骤 17 中的图像 2,3 Top Shield Plate Removal, Disconnect the interconnect cable: 步骤 17 中的图像 3,3
    • Use the point of a spudger to push the interconnect cable's metal latch down and away from the connector to unlock it.
    • Keep the latch in its unlocked position and carefully pull the interconnect cable straight out of its socket.
    • During reassembly, push the latch into its unlocked position and insert the cable into its socket. Then, push the latch back in place to lock the cable.
  18. Top Shield Plate Removal, Disconnect the antenna cables: 步骤 18 中的图像 1,3 Top Shield Plate Removal, Disconnect the antenna cables: 步骤 18 中的图像 2,3 Top Shield Plate Removal, Disconnect the antenna cables: 步骤 18 中的图像 3,3
    • Insert the flat end of a spudger under the metal neck of one of the antenna cable's coaxial connectors and lift straight up to disconnect it.
    • Repeat the process to disconnect the other antenna cable.
    • To reconnect a cable, hold the metal connector head over its socket and press down with the flat end of a spudger until the connector snaps into place. Don't try to force the connector into place. If you're having trouble, reposition the connector and try again.
  19. Top Shield Plate Removal, Peel up the antenna cable tape: 步骤 19 中的图像 1,2 Top Shield Plate Removal, Peel up the antenna cable tape: 步骤 19 中的图像 2,2
    • A piece of tape and a block of foam secure the antenna cables to the heatsink shield.
    • Gently lift both antenna cables to separate the tape from the heatsink shield.
  20. Top Shield Plate Removal, Peel up the antenna cable foam: 步骤 20 中的图像 1,2 Top Shield Plate Removal, Peel up the antenna cable foam: 步骤 20 中的图像 2,2
    • Light adhesive secures the foam block to the heatsink shield.
    • Use tweezers to gently peel up the foam block.
    • If you're having trouble, heat an iOpener and apply it to the foam for one minute to soften the adhesive. If you don't have an iOpener, you can use a hair dryer instead.
  21. Top Shield Plate Removal, Reposition the antenna cables: 步骤 21 中的图像 1,3 Top Shield Plate Removal, Reposition the antenna cables: 步骤 21 中的图像 2,3 Top Shield Plate Removal, Reposition the antenna cables: 步骤 21 中的图像 3,3
    • Move the antenna cables over the side of your PlayStation so they're out of the way.
    • During reassembly, use this photo as a reference to put the antenna cables back in their original position.
  22. Top Shield Plate Removal, Remove the top shield plate screws: 步骤 22 中的图像 1,2 Top Shield Plate Removal, Remove the top shield plate screws: 步骤 22 中的图像 2,2
    • Use a T8 Torx Security screwdriver to remove the thirty 7.5 mm‑long screws securing the top shield plate.
  23. Top Shield Plate Removal, Separate the top shield plate: 步骤 23 中的图像 1,3 Top Shield Plate Removal, Separate the top shield plate: 步骤 23 中的图像 2,3 Top Shield Plate Removal, Separate the top shield plate: 步骤 23 中的图像 3,3
    • Thermal pads bond the top shield plate to the main board. Depending on the age of your device and conditions of the pads, it may take significant force to separate the plate.
    • Insert the flat end of a spudger between the top shield plate and the main board and pry up to release the plate. Work your way around the perimeter until it separates completely.
  24. Top Shield Plate Removal, Remove the top shield plate: 步骤 24 中的图像 1,2 Top Shield Plate Removal, Remove the top shield plate: 步骤 24 中的图像 2,2
    • Lift and remove the top shield plate.
    • During reassembly, this is a good point to replace any thermal pads on the top of the main board, if necessary. The pads may be stuck to both the top shield plate and the main board.
    • It's important that the replacement pads are the same thickness as the originals, otherwise the foam around the APU may not seal properly.
结论
Spencer Day
于09/14/22注册
165,294 声望
创作了1,047篇指南
团队
iFixit iFixit 的会员
Staff
124 名成员
创作了24,293篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 117
