跳转到主内容
Tivax MiTraveler 10Q-8 USB Charging Port Replacement
你所需要的
  1. Tivax MiTraveler 10Q-8 USB Charging Port Replacement, Rear Case: 步骤 1 中的图像 1,2 Tivax MiTraveler 10Q-8 USB Charging Port Replacement, Rear Case: 步骤 1 中的图像 2,2
    • With the device face down, slide the charging port cover off on the left side of device.
  2. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 2 中的图像 1,1
    • Locate a Phillips 2.88mm screw at the charging port.
  3. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 3 中的图像 1,1
    • Use a PH000 Philips head screwdriver to remove screw.
    • Remember lefty loosey, righty tighty
  4. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 4 中的图像 1,1
    • To pry the back plate off, use the plastic opening tool between the back plate and front plate; start at the headphone jack.
    • Make sure the lip of the plastic opening tool is face up.
  5. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 5 中的图像 1,2 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 5 中的图像 2,2
    • Move around the device with the plastic opening tool, pushing down to release the back plate from clips.
    • You will hear popping sounds when you work around the device.
  6. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 6 中的图像 1,2 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 6 中的图像 2,2
    • Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
  7. Tivax MiTraveler 10Q-8 USB Charging Port Replacement, Battery: 步骤 7 中的图像 1,1
    • The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
  8. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 8 中的图像 1,1
    • Two wires, one red and one black, which run from the motherboard to the battery, need to be desoldered from the motherboard.
    • Review how to solder here.
  9. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 9 中的图像 1,2 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 9 中的图像 2,2
    • Work the soldering gun on the red wire where it is connected to the motherboard. It should release from the motherboard.
    • Work the soldering gun on the black wire where it is connected to the motherboard. It will release from the motherboard.
  10. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 10 中的图像 1,3 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 10 中的图像 2,3 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 10 中的图像 3,3
    • Once both wires have been desoldered, remove the battery from the device.
  11. Tivax MiTraveler 10Q-8 USB Charging Port Replacement, USB Charging Port: 步骤 11 中的图像 1,2 Tivax MiTraveler 10Q-8 USB Charging Port Replacement, USB Charging Port: 步骤 11 中的图像 2,2
    • With the device facing down, the USB charging port can be located on the left side of the device directly on the motherboard. The mini HDMI port will be above the charging port and the micro SD port will be below, with the charging port in the middle of the two.
    • Make sure all power is extinguished by following the steps to remove the battery.
    • The charging port will be soldered down at all four corners; each prong will need to be soldered off.
    • Review How to Solder Here
  12. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 12 中的图像 1,3 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 12 中的图像 2,3 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 12 中的图像 3,3
    • Work the iron on one prong at a time that is soldered to the motherboard. The USB port will release from the motherboard.
  13. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 13 中的图像 1,3 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 13 中的图像 2,3 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 步骤 13 中的图像 3,3
    • Repeat steps 2-5 for the soldering of the other 3 prongs.
    • Once all four prongs have been soldered off the USB charging port will remove from the device.
结论
2等其他人完成本指南。
Conor Langenbahn
于03/11/15注册
228 声望
创作了2篇指南
团队
Colorado Springs, Team 4-3, Panko Spring 2015 Colorado Springs, Team 4-3, Panko Spring 2015 的会员
UCCS-PANKO-S15S4G3
3 名成员
创作了10篇指南
一条评论
You forgot to desolder the leads on the board first, if you don't, the lands on the board can be lifted off and you lose contact to the charge circuit.
da ha - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 371
