简介
This is a guide on how to replace a Tivax MiTraveler 10Q-8 Motherboard. When using this tablet and you notice it might be running slower or not at all, it might be time to replace the Motherboard. The Motherboard is important for the distribution of electricity through the device. Replacement requires soldering and the device's battery to be removed. If needed review How To Solder and Desolder Connections.
你所需要的
With the device face down, slide the charging port cover off on the left side of device.
The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
With the face of the device down, locate the speaker in the upper right corner. The black oval shaped object.
The speaker will be connected to two wires; one black and one red. Both run to the motherboard.
The wires will need to be soldered off the motherboard.
Locate where both wires are soldered to the motherboard.
Review How to Solder Here
To remove the black ribbon connector, flip the black portion of the connector upward.
Pull on the ribbon to remove from the connector.
