跳转到主内容
Tivax MiTraveler 10Q-8 Battery Replacement
你所需要的
  1. Tivax MiTraveler 10Q-8 Battery Replacement, Rear Case: 步骤 1 中的图像 1,2 Tivax MiTraveler 10Q-8 Battery Replacement, Rear Case: 步骤 1 中的图像 2,2
    • With the device face down, slide the charging port cover off on the left side of device.
  2. Tivax MiTraveler 10Q-8 Battery Replacement: 步骤 2 中的图像 1,1
    • Locate a Phillips 2.88mm screw at the charging port.
  3. Tivax MiTraveler 10Q-8 Battery Replacement: 步骤 3 中的图像 1,1
    • Use a PH000 Philips head screwdriver to remove screw.
    • Remember lefty loosey, righty tighty
  4. Tivax MiTraveler 10Q-8 Battery Replacement: 步骤 4 中的图像 1,1
    • To pry the back plate off, use the plastic opening tool between the back plate and front plate; start at the headphone jack.
    • Make sure the lip of the plastic opening tool is face up.
  5. Tivax MiTraveler 10Q-8 Battery Replacement: 步骤 5 中的图像 1,2 Tivax MiTraveler 10Q-8 Battery Replacement: 步骤 5 中的图像 2,2
    • Move around the device with the plastic opening tool, pushing down to release the back plate from clips.
    • You will hear popping sounds when you work around the device.
  6. Tivax MiTraveler 10Q-8 Battery Replacement: 步骤 6 中的图像 1,2 Tivax MiTraveler 10Q-8 Battery Replacement: 步骤 6 中的图像 2,2
    • Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
  7. Tivax MiTraveler 10Q-8 Battery Replacement, Battery: 步骤 7 中的图像 1,1
    • The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
  8. Tivax MiTraveler 10Q-8 Battery Replacement: 步骤 8 中的图像 1,1
    • Two wires, one red and one black, which run from the motherboard to the battery, need to be desoldered from the motherboard.
    • Review how to solder here.
  9. Tivax MiTraveler 10Q-8 Battery Replacement: 步骤 9 中的图像 1,2 Tivax MiTraveler 10Q-8 Battery Replacement: 步骤 9 中的图像 2,2
    • Work the soldering gun on the red wire where it is connected to the motherboard. It should release from the motherboard.
    • Work the soldering gun on the black wire where it is connected to the motherboard. It will release from the motherboard.
  10. Tivax MiTraveler 10Q-8 Battery Replacement: 步骤 10 中的图像 1,3 Tivax MiTraveler 10Q-8 Battery Replacement: 步骤 10 中的图像 2,3 Tivax MiTraveler 10Q-8 Battery Replacement: 步骤 10 中的图像 3,3
    • Once both wires have been desoldered, remove the battery from the device.
结论
Maria
于03/16/15注册
210 声望
创作了2篇指南
团队
Colorado Springs, Team 4-3, Panko Spring 2015 Colorado Springs, Team 4-3, Panko Spring 2015 的会员
UCCS-PANKO-S15S4G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 8
总计 845
