跳转到主内容
ThinkPad X1 Carbon Wireless Card Replacement
你所需要的
  1. ThinkPad X1 Carbon Wireless Card Replacement, Loosen Cover Screws: 步骤 1 中的图像 1,1
    • Using the #0 Phillips screwdriver, loosen the seven cover screws. they will not come all of the way out.
  2. ThinkPad X1 Carbon Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Using the spudger pop the cover loose and remove.
  3. ThinkPad X1 Carbon Wireless Card Replacement, Disconnect Battery: 步骤 3 中的图像 1,1
    • Use only plastic tools to disconnect battery cable
    • Slide battery connector in the direction if the arrow to disconnect.
    • You can leave the battery or remove it using the red circles for the screw locations.
  4. ThinkPad X1 Carbon Wireless Card Replacement: 步骤 4 中的图像 1,1
    • Remove screw holding the wireless card in place.
  5. ThinkPad X1 Carbon Wireless Card Replacement, Remove Antenna Cables: 步骤 5 中的图像 1,1
    • Carefully remove the antenna cables and slide out the card in the direction of the arrow.
    • The gray connector is on the top. The black connector is closer to the battery.
结论
3等其他人完成本指南。
Mike
于06/23/16注册
1,834 声望
创作了5篇指南
团队
iReconstruction iReconstruction 的会员
Business
1 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 33
总计 5,520
