跳转到主内容
ThinkPad X1 Carbon Fan Replacement
你所需要的
  1. ThinkPad X1 Carbon Fan Replacement, Loosen Cover Screws: 步骤 1 中的图像 1,1
    • Loosen the seven cover screws. They will not come out.
  2. ThinkPad X1 Carbon Fan Replacement, Remove Cover: 步骤 2 中的图像 1,1
    • Use a spudger to pop loose the cover and slide it off.
  3. ThinkPad X1 Carbon Fan Replacement, Disconnect Battery: 步骤 3 中的图像 1,1
    • Only use plastic to remove battery connector
    • Gently remove battery connector by pushing with the spudger in the direction of the arrow.
    • Remove four screws holding battery in place and remove battery.
    • The 4 perimeter screws also hold the tow audio speakers in place. And there is a 5th screw dead center of the battery. The battery cable is not easy to remove, nor is it easy to re-connect.
  4. ThinkPad X1 Carbon Fan Replacement, Disconnect Fan Cable: 步骤 5 中的图像 1,1
    • Use your spudger to open the connector in the direction of the arrow. Carefully remove the ribbon cable
    • These connectors are very delicate. Use care when removing cables.
  5. ThinkPad X1 Carbon Fan Replacement, Remove Fan: 步骤 6 中的图像 1,1
    • Loosen screws and pull fan up and out of the case.
    • Be sure to apply heat sink paste when putting fan back on CPU
结论
9等其他人完成本指南。
Mike
于06/23/16注册
1,834 声望
创作了5篇指南
团队
iReconstruction iReconstruction 的会员
Business
1 名成员
创作了11篇指南
一条评论
Great guide. I do recommend ordering the recommended tools, especially the spudger. There isn’t a lot of room to get the battery cable disconnected, so some of my other spudgers weren’t sturdy enough or wouldn’t have fit. My computer is working again and I didn’t have to pay a king’s ransom and wait 3 weeks (hey, I’m in Montana! I’m lucky to find anyone to fix a computer). Thanks!
marceec - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 14
过去 30 天: 84
总计 12,895
