跳转到主内容
ThinkPad X1 Carbon Battery Replacement
你所需要的
  1. ThinkPad X1 Carbon Battery Replacement, Loosen Cover Screws: 步骤 1 中的图像 1,1
    • Loosen the seven cover screws. They will not come out.
  2. ThinkPad X1 Carbon Battery Replacement, Remove Cover: 步骤 2 中的图像 1,1
    • Use spudger to pop loose cover and slide off.
  3. ThinkPad X1 Carbon Battery Replacement, Disconnect Battery: 步骤 3 中的图像 1,1
    • Only use plastic to remove battery connector
    • Gently remove battery connector by pushing with the spudger in the direction of the arrow.
    • Remove five screws holding battery in place and remove battery.
    Mine had a fifth screw (inside that circle in the center of the battery)
    Vinod Kurup - 回复
结论
9等其他人完成本指南。
Mike
于06/23/16注册
1,834 声望
创作了5篇指南
团队
iReconstruction iReconstruction 的会员
Business
1 名成员
创作了11篇指南
3条评论
bonjour,
depuis que j’ai changé la batterie, elle ne charge plus… j’ai remis celle d’origine, idem…
Une idée?
merci d’avance.
Franck D'ALOIA - 回复
Bonjour,
J’ai le même phénomène que celui décrit plus haut par Franck D’ALOIA. La batterie de remplacement indique 100% de charge mais ne tient que 10min tout au plus.
Une idée ??
Merci à vous
Lamine Bouras - 回复
Minor correction to step #3 - the text says "remove 4 screws", but reality - and the photo - is that there are five screws.
Important: Note that the center one in the circular hole in the battery (under the trackpad) is a shorter length than the others.
davidhollway - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 48
过去 30 天: 256
总计 19,428
