跳转到主内容
加入维修社区 - 创建账户
ThinkPad T420 Memory Replacement
你所需要的
    1. ThinkPad T420 Memory Replacement, Change note: 步骤 1 中的图像 1,2 ThinkPad T420 Memory Replacement, Change note: 步骤 1 中的图像 2,2
      在这个步骤中使用的工具:
      Essential Electronics Toolkit
      $29.95
      • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
      • If you are interested in a refurbished kit stock levels change frequently but can be found here.
      添加评论
    1. ThinkPad T420 Memory Replacement, Unlock the battery: 步骤 2 中的图像 1,3 ThinkPad T420 Memory Replacement, Unlock the battery: 步骤 2 中的图像 2,3 ThinkPad T420 Memory Replacement, Unlock the battery: 步骤 2 中的图像 3,3
      • If completing a step like a clone of your old hard drive/SSD, DO NOT remove the battery until the process is complete!
      • Unlock the latch locking the battery in the laptop.
      • NOTE: To remove the battery, the tab must be held in to avoid having the lock reinitiate inside the laptop.
      询问修复机器人
      添加评论
    2. ThinkPad T420 Memory Replacement, Release the battery: 步骤 3 中的图像 1,3 ThinkPad T420 Memory Replacement, Release the battery: 步骤 3 中的图像 2,3 ThinkPad T420 Memory Replacement, Release the battery: 步骤 3 中的图像 3,3
      • After unlocking the battery, remove the battery from the reverse way it is installed to remove it from the laptop.
      询问修复机器人
      添加评论
    1. ThinkPad T420 Memory Replacement, Remove the RAM door: 步骤 4 中的图像 1,3 ThinkPad T420 Memory Replacement, Remove the RAM door: 步骤 4 中的图像 2,3 ThinkPad T420 Memory Replacement, Remove the RAM door: 步骤 4 中的图像 3,3
      • EET owners: Your kit has this bit. No purchase needed.
      • If you are removing this cover to upgrade/replace your lower RAM module, the keyboard screw DOES NOT need to be removed.
      • WWAN ready systems ship with antenna covers over these cables. Someone installed a WLAN card in this T420 which disabled the better card and was removed.
      • Loosen the screw in red (Phillips #2). This screw stays captive in the bottom RAM door cover, and does not need to be removed.
      • Pull the cover up with a fingernail or a nonmarring pry tool.
      • Remove the screw retaining the keyboard.
      询问修复机器人
      添加评论
    2. ThinkPad T420 Memory Replacement, Remove the keyboard: 步骤 5 中的图像 1,3 ThinkPad T420 Memory Replacement, Remove the keyboard: 步骤 5 中的图像 2,3 ThinkPad T420 Memory Replacement, Remove the keyboard: 步骤 5 中的图像 3,3
      • Open the laptop.
      • To remove the keyboard, release the keyboard hooks using a plastic pry tool.
      • Once the keyboard is loose, remove it from the chassis.
      询问修复机器人
      添加评论
    3. ThinkPad T420 Memory Replacement, Disconnect the keyboard: 步骤 6 中的图像 1,3 ThinkPad T420 Memory Replacement, Disconnect the keyboard: 步骤 6 中的图像 2,3 ThinkPad T420 Memory Replacement, Disconnect the keyboard: 步骤 6 中的图像 3,3
      • To reinstall the keyboard, refer to the steps in this guide.
      • This step can be skipped if you remove the keyboard to upgrade/replace the RAM. However, disconnecting it may allow for better access to the upper (Keyboard) RAM module.
      • If you have a can of compressed air available, some of the dust can be removed at this point. Further disassembly is required for a full cleaning.
      • Disconnect the keyboard from the motherboard. Use a plastic pry tool for this step.
      询问修复机器人
      添加评论
    1. ThinkPad T420 Memory Replacement, RAM module - Bottom: 步骤 7 中的图像 1,3 ThinkPad T420 Memory Replacement, RAM module - Bottom: 步骤 7 中的图像 2,3 ThinkPad T420 Memory Replacement, RAM module - Bottom: 步骤 7 中的图像 3,3
      • Unclip the RAM module by pulling the memory retention tabs back.
      • Remove the existing module by pulling the module from the side, at a 90 degree angle.
      询问修复机器人
      添加评论
    1. ThinkPad T420 Memory Replacement, RAM module - keyboard: 步骤 8 中的图像 1,3 ThinkPad T420 Memory Replacement, RAM module - keyboard: 步骤 8 中的图像 2,3 ThinkPad T420 Memory Replacement, RAM module - keyboard: 步骤 8 中的图像 3,3
      • Lift the plastic cover hiding the RAM module.
      • Unlatch the tabs retaining the memory module.
      • Pull the module out from a 90 degree angle.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
16等其他人完成本指南。
Nick
于11/10/09注册
105,467 声望
创作了72篇指南
团队
Master Techs Master Techs 的会员
Community
334 名成员
创作了4,881篇指南
2指南评论
What tool might one use as a pry?
commander - 回复 分享
The plastic pry tool will also work for the bottom RAM/mSATA part. I can usually get it open without the assistance of pry tools.
Nick - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 33
过去 30 天: 128
总计 22,113
