跳转到主内容
The Sharper Image Literati Tablet SD Port Replacement
你所需要的
  1. The Sharper Image Literati Tablet SD Port Replacement, Battery: 步骤 1 中的图像 1,1
    • Wedge plastic spudger tool between the back panel and the body of device.
    • Pry apart the back panel and the device.
  2. The Sharper Image Literati Tablet SD Port Replacement: 步骤 2 中的图像 1,1
    • Desolder the battery wires from the circuit board.
  3. The Sharper Image Literati Tablet SD Port Replacement: 步骤 3 中的图像 1,1
    • Warm the battery with a hair dryer.
    • Be carful not to over-heat the battery, this could cause the battery to ignite.
  4. The Sharper Image Literati Tablet SD Port Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
    • Do not bend or puncture the battery. Work slowly and carefully.
  5. The Sharper Image Literati Tablet SD Port Replacement, SD Port: 步骤 5 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
  6. The Sharper Image Literati Tablet SD Port Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove three 4 mm screws from the circuit board containing the headphone jack and power jack.
  7. The Sharper Image Literati Tablet SD Port Replacement: 步骤 7 中的图像 1,1
    • Remove the circuit board.
  8. The Sharper Image Literati Tablet SD Port Replacement: 步骤 8 中的图像 1,1
    • Unclip ZIF clip from the chip and unplug ribbon cable.
  9. The Sharper Image Literati Tablet SD Port Replacement: 步骤 9 中的图像 1,1
    • Detach the peripheral edge with plastic wedge.
    • This may require a little hard pulling.
  10. The Sharper Image Literati Tablet SD Port Replacement: 步骤 10 中的图像 1,1
    • Remove peripheral silver edge.
  11. The Sharper Image Literati Tablet SD Port Replacement: 步骤 11 中的图像 1,1
    • Remove screws from the large metal shielding.
  12. The Sharper Image Literati Tablet SD Port Replacement: 步骤 12 中的图像 1,1
    • Remove the silver backing plate and the adhered SD port chip.
结论
Spencer Dodder
于03/21/18注册
560 声望
创作了4篇指南
团队
IUPUI, Team S5-G4, Baechle Spring 2018 IUPUI, Team S5-G4, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S5G4
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 344
