简介
After many years of use, the solar panels in your Texas Instruments TI-30X IIS will slowly decay, and their capacity to charge will diminish. Thankfully, this can be easily fixed with a bit of time, patience, and some basic tools.
This guide demonstrates how to remove and replace the solar panels.
Caution: Desoldering and soldering presents the potential for device damage and burns. Always solder in well-ventilated environments.
你所需要的
Use a Phillips #000 screwdriver to remove the four 5 mm screws securing the back panel.
Gently lift up the front of the motherboard, at the top of the calculator.
Desolder the positive and negative terminals on the solar panel
Use the tip of a spudger to "walk" the solar panel out of its housing, by pushing it down through the two cutouts until it slides out of the bottom.
Remove the solar panel.
另外一个人完成了本指南。
