跳转到主内容
Texas Instruments TI-30X IIS Solar Panel Replacement
你所需要的
  1. Texas Instruments TI-30X IIS Solar Panel Replacement, Solar Panel: 步骤 1 中的图像 1,2 Texas Instruments TI-30X IIS Solar Panel Replacement, Solar Panel: 步骤 1 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the four 5 mm screws securing the back panel.
  2. Texas Instruments TI-30X IIS Solar Panel Replacement: 步骤 2 中的图像 1,1
    • Wedge an opening tool in the gap between the front and back panel, then gently pry until the tabs release.
  3. Texas Instruments TI-30X IIS Solar Panel Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the two 3 mm screws securing the motherboard.
  4. Texas Instruments TI-30X IIS Solar Panel Replacement: 步骤 4 中的图像 1,1
    • Desoldering and soldering presents a potential for device damage. Always solder/desolder in well-ventilated environments and with care not to burn yourself.
    • Desolder the positive the negative terminals on the motherboard.
  5. Texas Instruments TI-30X IIS Solar Panel Replacement: 步骤 5 中的图像 1,2 Texas Instruments TI-30X IIS Solar Panel Replacement: 步骤 5 中的图像 2,2
    • Gently lift up the front of the motherboard, at the top of the calculator.
    • Desolder the positive and negative terminals on the solar panel
    • Use the tip of a spudger to "walk" the solar panel out of its housing, by pushing it down through the two cutouts until it slides out of the bottom.
    • Remove the solar panel.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 27
总计 662
