当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Use your hands or pliers to flatten out a bobby pin.
Any long, thin, metal object will work to help feed the string and cord through the poles.
Drop the bobby pin and string through the tent pole pieces one by one.
Once the bobby pin reaches the opposite end of each pole, slowly pull the string to feed the shock cord through.
Once the last piece has been threaded, untie or cut the string from the shock cord.
Tie a large knot against the right end of the last piece.
The knot must be large enough to prevent the shock cord from slipping through the pole.
Cut the shock cord from the left end of the first pole piece leaving room on the end for knots.
Leaving extra shock cord on the end will also allow you to adjust the tension in the shock cord later on.
Tie a large knot around the tent pole end piece.
Fit the end piece into the left end of the first pole.
If your poles do not come with an end piece, simply tie a large knot in the shock cord. The knot must be large enough to prevent the shock cord from pulling through.
Disconnect the pole pieces.
Fold the pieces to test the shock cord tension.
If the shock cord is too tight, reconnect the poles and adjust the shock cord length between the left end of the first pole and the end piece.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
