跳转到主内容
Teenage Engineering OP-Z Rubber Feet Replacement
你所需要的
  1. Teenage Engineering OP-Z Rubber Feet Replacement, Back Cover: 步骤 1 中的图像 1,3 Teenage Engineering OP-Z Rubber Feet Replacement, Back Cover: 步骤 1 中的图像 2,3 Teenage Engineering OP-Z Rubber Feet Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Rubber Feet Replacement: 步骤 2 中的图像 1,2 Teenage Engineering OP-Z Rubber Feet Replacement: 步骤 2 中的图像 2,2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Rubber Feet Replacement: 步骤 3 中的图像 1,1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Rubber Feet Replacement, Rubber Feet: 步骤 4 中的图像 1,1
    • Remove the four Phillips #0 screws from the back of the rubber feet.
  5. Teenage Engineering OP-Z Rubber Feet Replacement: 步骤 5 中的图像 1,2 Teenage Engineering OP-Z Rubber Feet Replacement: 步骤 5 中的图像 2,2
    • Separate the front and rear part of the rubber feet from the back cover.
  6. Teenage Engineering OP-Z Rubber Feet Replacement: 步骤 6 中的图像 1,1
    • When reassembling make sure to correctly align the front and rear part of the rubber feet. The notch and grove should interlock and fit into the cutout of the back cover.
结论
Tobias Isakeit
于03/31/14注册
118,058 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,086篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 1,608
