跳转到主内容
Teenage Engineering OP-Z Highway Flex Cable Replacement
你所需要的
  1. Teenage Engineering OP-Z Highway Flex Cable Replacement, Back Cover: 步骤 1 中的图像 1,3 Teenage Engineering OP-Z Highway Flex Cable Replacement, Back Cover: 步骤 1 中的图像 2,3 Teenage Engineering OP-Z Highway Flex Cable Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 2 中的图像 1,2 Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 2 中的图像 2,2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 3 中的图像 1,1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Highway Flex Cable Replacement, Battery: 步骤 4 中的图像 1,2 Teenage Engineering OP-Z Highway Flex Cable Replacement, Battery: 步骤 4 中的图像 2,2
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 5 中的图像 1,2 Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 5 中的图像 2,2
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
  6. Teenage Engineering OP-Z Highway Flex Cable Replacement, Expansion Module: 步骤 6 中的图像 1,2 Teenage Engineering OP-Z Highway Flex Cable Replacement, Expansion Module: 步骤 6 中的图像 2,2
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
  7. Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 7 中的图像 1,1
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
  8. Teenage Engineering OP-Z Highway Flex Cable Replacement, Midframe: 步骤 8 中的图像 1,1
    • Remove the five Torx T4 screws.
  9. Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 9 中的图像 1,2 Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 9 中的图像 2,2
    • Place a spudger in the cutout of the extension module to lift the midframe.
    • Be careful not to damage the highway flex cable underneath.
    • Don’t remove the midframe yet. It is still connected to the rest of the OP-Z.
  10. Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 10 中的图像 1,3 Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 10 中的图像 2,3 Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 10 中的图像 3,3
    • Flip the midframe over to gain access to the flex cable connector underneath.
  11. Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 11 中的图像 1,2 Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 11 中的图像 2,2
    • Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
  12. Teenage Engineering OP-Z Highway Flex Cable Replacement, Highway Flex Cable: 步骤 12 中的图像 1,2 Teenage Engineering OP-Z Highway Flex Cable Replacement, Highway Flex Cable: 步骤 12 中的图像 2,2
    • Use a spudger to disconnect the highway flex cable from the DSP board.
  13. Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 13 中的图像 1,2 Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 13 中的图像 2,2
    • Use the spudger to disconnect the flex cable from the encoder board.
  14. Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 14 中的图像 1,3 Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 14 中的图像 2,3 Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 14 中的图像 3,3
    • Slowly pry the USB-C connector out of its recess. Use the flat end of a spudger on the small nib on the USB-C board.
    • The connector is slightly glued down.
  15. Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 15 中的图像 1,3 Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 15 中的图像 2,3 Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 15 中的图像 3,3
    • Insert the pointy end of the spudger into the line-out jack and lever it up carefully.
    • The jack connector might sit tight and is slightly glued down.
  16. Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 16 中的图像 1,3 Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 16 中的图像 2,3 Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 16 中的图像 3,3
    • The highway flex cable is slightly adhered to the midframe. To remove it, gently push it out from underneath.
    • A small transparent part may pop out. This is the light guide for the bluetooth indicator. Just hinge it back onto the midframe as seen here.
  17. Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 17 中的图像 1,3 Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 17 中的图像 2,3 Teenage Engineering OP-Z Highway Flex Cable Replacement: 步骤 17 中的图像 3,3
    • Peel the highway flex cable off the midframe and remove it.
结论
2等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
118,058 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,086篇指南
3条评论
It worked! Sort of. I bought a highway flex cable replacement and a new battery hoping it would solve an issue. The good news is I was able to replace it, and it’s function as before I replaced the flex cable. The only challenge really was that the audio cable plug in the new flex cable assemble was slightly bigger than the one I removed. I really had to force it down. During reassemble it was important to start left to right too - and it was easier to plug that last cable before installing the audio and USB C sockets. The issue I was trying to solve: My OP-Z will only power on when plugged in. I bought the OP Z used, and it worked fine for a while. But for reasons I can’t explain it stopped working with battery power alone. I tried all the solutions I found online including resetting the battery, firmware, etc. I’m just sharing this in case someone else has the same issue. Other than that, the new flex cable works just like the one it replaced, and I have an extra one now! Thank you!!!
thompsonkmt - 回复
I didnt replace my highway flex cable but I did repair the rotary encoders cuz the magnet holders kept popping out of the bearings.
Eric M - 回复
ATTENTION, some devices do not have Torx 4 screws, but much smaller ones! Why hasn't this been corrected here all this time? ...I really wonder what the point of this kind of tutorial is, if the dimensions are wrong...?
Hybyscut - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 52
总计 2,450
