跳转到主内容
Teenage Engineering OP-Z Function Key Plastic Buttons Replacement
你所需要的
  1. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Back Cover: 步骤 1 中的图像 1,3 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Back Cover: 步骤 1 中的图像 2,3 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 2 中的图像 1,2 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 2 中的图像 2,2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 3 中的图像 1,1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Battery: 步骤 4 中的图像 1,2 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Battery: 步骤 4 中的图像 2,2
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 5 中的图像 1,2 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 5 中的图像 2,2
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
  6. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Expansion Module: 步骤 6 中的图像 1,2 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Expansion Module: 步骤 6 中的图像 2,2
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
  7. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 7 中的图像 1,1
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
  8. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Midframe: 步骤 8 中的图像 1,1
    • Remove the five Torx T4 screws.
  9. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 9 中的图像 1,2 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 9 中的图像 2,2
    • Place a spudger in the cutout of the extension module to lift the midframe.
    • Be careful not to damage the highway flex cable underneath.
    • Don’t remove the midframe yet. It is still connected to the rest of the OP-Z.
  10. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 10 中的图像 1,3 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 10 中的图像 2,3 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 10 中的图像 3,3
    • Flip the midframe over to gain access to the flex cable connector underneath.
  11. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 11 中的图像 1,2 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 11 中的图像 2,2
    • Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
  12. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Function Key Plastic Buttons: 步骤 12 中的图像 1,2 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Function Key Plastic Buttons: 步骤 12 中的图像 2,2
    • Use a spudger to push the first set of function buttons inwards.
  13. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 13 中的图像 1,1
    • Remove the first set of function buttons.
    • This pair has a circular alignment post between the buttons and a dot mark on one of the buttons.
  14. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 14 中的图像 1,2 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 14 中的图像 2,2
    • Use a spudger to push the second set of function buttons inwards.
  15. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 步骤 15 中的图像 1,1
    • Remove the second set of function buttons.
    • This pair has an elliptical alignment post between the buttons and a straight mark on one of the buttons.
结论
Tobias Isakeit
于03/31/14注册
118,058 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,086篇指南
一条评论
Torx t4 screwdriver doesn’t work! Seems too big. Wasting too much money so far to fix something that shouldn’t have worn to breaking point so quickly. Gutted.
Sam Lsn - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 41
总计 1,653
