跳转到主内容
Teenage Engineering OP-Z Expansion Module Replacement
  1. Teenage Engineering OP-Z Expansion Module Replacement, Back Cover: 步骤 1 中的图像 1,3 Teenage Engineering OP-Z Expansion Module Replacement, Back Cover: 步骤 1 中的图像 2,3 Teenage Engineering OP-Z Expansion Module Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Expansion Module Replacement: 步骤 2 中的图像 1,2 Teenage Engineering OP-Z Expansion Module Replacement: 步骤 2 中的图像 2,2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Expansion Module Replacement: 步骤 3 中的图像 1,1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Expansion Module Replacement, Expansion Module: 步骤 4 中的图像 1,2 Teenage Engineering OP-Z Expansion Module Replacement, Expansion Module: 步骤 4 中的图像 2,2
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
  5. Teenage Engineering OP-Z Expansion Module Replacement: 步骤 5 中的图像 1,1
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
结论
Tobias Isakeit
于03/31/14注册
129,498 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,145篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 1,267
