跳转到主内容
Teenage Engineering OP-Z Battery Replacement
你所需要的
  1. Teenage Engineering OP-Z Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 Teenage Engineering OP-Z Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 Teenage Engineering OP-Z Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Battery Replacement: 步骤 2 中的图像 1,2 Teenage Engineering OP-Z Battery Replacement: 步骤 2 中的图像 2,2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Battery Replacement, Battery: 步骤 4 中的图像 1,2 Teenage Engineering OP-Z Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Battery Replacement: 步骤 5 中的图像 1,2 Teenage Engineering OP-Z Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
结论
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Ask our Answers community for help.
4等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
117,756 声望
创作了188篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,542篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 49
过去 30 天: 160
总计 6,932
