跳转到主内容
Teenage Engineering OP-1 Flex Cable Replacement
你所需要的
  1. Teenage Engineering OP-1 Flex Cable Replacement, key removal: 步骤 1 中的图像 1,3 Teenage Engineering OP-1 Flex Cable Replacement, key removal: 步骤 1 中的图像 2,3 Teenage Engineering OP-1 Flex Cable Replacement, key removal: 步骤 1 中的图像 3,3
    • To get to the screws beneath the keyboard you need to take some keys off. You can use either an opening tool or an opening pick. The first picture shows how it should look like with all the necessary keys off (12 in total).
    • The four longer keys from the fingerboard are to be handled from the left side to get them off.
    • The eight smaller keys need to be levered from the bottom up.
  2. Teenage Engineering OP-1 Flex Cable Replacement, removing scissors mechanisms: 步骤 2 中的图像 1,2 Teenage Engineering OP-1 Flex Cable Replacement, removing scissors mechanisms: 步骤 2 中的图像 2,2
    • The scissor mechanism of the eight small keys are obstructing the underlying screws.
    • By using again an opening tool or opening pick these can be snapped off easily.
    • When reassembling be sure to place them in with the correct side facing upwards.
  3. Teenage Engineering OP-1 Flex Cable Replacement, unscrew keyboard: 步骤 3 中的图像 1,3 Teenage Engineering OP-1 Flex Cable Replacement, unscrew keyboard: 步骤 3 中的图像 2,3 Teenage Engineering OP-1 Flex Cable Replacement, unscrew keyboard: 步骤 3 中的图像 3,3
    • Loosen those 12 screws with a Phillips #00 screwdriver.
    • Then just pull off the four rotary knobs and the volume knob.
    • Now it is possible to slightly lift the keyboard and set it back.
  4. Teenage Engineering OP-1 Flex Cable Replacement, unplug and remove keyboard: 步骤 4 中的图像 1,1
    • Unlock the flex cables by pushing the two black nibs on both sides of each connector.
    • Now you can pull the flex cables out and remove the keyboard completely.
  5. Teenage Engineering OP-1 Flex Cable Replacement, remove display: 步骤 5 中的图像 1,3 Teenage Engineering OP-1 Flex Cable Replacement, remove display: 步骤 5 中的图像 2,3 Teenage Engineering OP-1 Flex Cable Replacement, remove display: 步骤 5 中的图像 3,3
    • Open the display cable connector by using a plastic opening tool to flip the latch upwards.
    • The display is held in place with a mild adhesive. A spudger helps you to get it free.
    • Now you can unplug the cable and take out the whole display.
  6. Teenage Engineering OP-1 Flex Cable Replacement, DSP Board: 步骤 6 中的图像 1,2 Teenage Engineering OP-1 Flex Cable Replacement, DSP Board: 步骤 6 中的图像 2,2
    • Disconnect the battery connector from the DSP board.
    • Unscrew the two Phillips #00 screws holding the board down.
  7. Teenage Engineering OP-1 Flex Cable Replacement: 步骤 7 中的图像 1,2 Teenage Engineering OP-1 Flex Cable Replacement: 步骤 7 中的图像 2,2
    • Now you can carefully lift the DSP board to access the flex cable connector underneath.
    • Disconnect the flex cable by using a spudger and remove the DSP board.
  8. Teenage Engineering OP-1 Flex Cable Replacement, Flex Cable: 步骤 8 中的图像 1,2 Teenage Engineering OP-1 Flex Cable Replacement, Flex Cable: 步骤 8 中的图像 2,2
    • Flip the OP-1 over to open the back panel giving you access to the connector board.
    • Disconnect the flex cable from the connector board.
  9. Teenage Engineering OP-1 Flex Cable Replacement: 步骤 9 中的图像 1,2 Teenage Engineering OP-1 Flex Cable Replacement: 步骤 9 中的图像 2,2
    • Returning to the front side you can unplug the flex cable from the UI board.
    • Now the flex cable is free and can be pulled out completely.
结论
3等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
129,193 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,145篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 32
总计 5,337
