跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide will help you resolve any problem with your speaker on your Teddy Ruxpin model #17262DS. If the volume, sound quality, or general audio qualities of your bear are lacking this guide should help you fix those issues. A Phillips #1 screwdriver is required to complete this guide. Desoldering is also required so be sure to look at the desoldering guide for help.
  1. Remove the vest covering the back of the bear. Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Pull the tab outward to remove the protective plate for the batteries.
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Cut the orange shirt and zip tie. Remove the zip tie. Remove the zip tie.
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Cut across the back seam of the head of the bear along the arrow.
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Remove the interior of the doll. Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear. This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Extract each arm button. Pull on the stuffing of the bear and not the wire to remove the arm button.
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Pull off the rest of the outside layer of the bear. Pull off the rest of the outside layer of the bear.
    • Pull off the rest of the outside layer of the bear.
  9. Unplug the arms from the main body.
    • Unplug the arms from the main body.
  10. Unscrew the eleven circled 12.5mm Phillips #1 screws. Remove the top of the housing to access the electronics inside. Remove the top of the housing to access the electronics inside.
    • Unscrew the eleven circled 12.5mm Phillips #1 screws.
    • Remove the top of the housing to access the electronics inside.
  11. Unscrew the two 12.5mm Phillips #1 screws holding the speaker cap on and remove the speaker cap. Unscrew the two 12.5mm Phillips #1 screws holding the speaker cap on and remove the speaker cap.
    • Unscrew the two 12.5mm Phillips #1 screws holding the speaker cap on and remove the speaker cap.
  12. Desolder the wire from the speaker and replace.
    • Desolder the wire from the speaker and replace.
结论
Jayin Patel
于2020年01月23日注册
376 信誉积分
创作了4篇指南
团队
Cal Poly, Team S18-G5, White Winter 2020 Cal Poly, Team S18-G5, White Winter 2020 的会员
CPSU-WHITE-W20S18G5
4 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 10
总计 165
